メインコンテンツにスキップ
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
20回答 すべてを表示
Broken Ribbon Cable Clip on Backing
Hey Guys !
So upon looking to figure out what was wrong with my keyboard/power I discovered the ribbon cable connector on the back part of my laptop was off ! What do I do ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There are a couple of styles of connectors for keyboards, one is the Zero Insertions Force (ZIF) that has a bail. which may be missing if the ribbon cable came loose on its own. The other style is the Low Insertion Force (LIF) that you just carefully push the ribbon cable in and make sure that the cable is inserted evenly.
If the connector is a ZIF connector and the bail is missing then try holding the ribbon cable by inserting a piece of thin card stock into the connector on the opposite side of the contacts. Use a piece of tape to hold the card stock in place.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Samantha Richter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 867
