メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
20回答 すべてを表示
No Charging after Battery replacement. Old one has no function too.
Hello!
i put in a new battery into my iphone 5 (the old one was still working but wouldnt hold long), after replacement of the battery the phone worked fine. but after the first discharge it showed the battery logo with 3 small red stripes, it does recognize the charging cable but it won`t charge even after 12h+ of loading at the charger.
i thought maybe the new battery is dead so i installed the old working battery again and had the same problem like the new one. did i break something on the board or is there a fix for this?
i did battery repairs on iphones before and never had a problem, so i guess something is wrong here?
/are there any schematics so i could measure the current on the board?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
I've come across this problem in the past and spent many hours seeking solutions. Unfortunately, the best conclusion I could reach, is that something on the logic board was damaged when disconnecting the battery. This implies that you now a defective logic board and shouldn't expect to find any easier solution that replacing it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
thats my thought too, but i`d like to verify this with a measurement.
/also it worked after the replacement. it stopped working after the first discharge.
さんによる
コメントを追加
TriStar switching ic switches between mains and battery (u2)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
einself さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 37
