メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad Air Wi-Fi +セルラーモデル、モデル番号はA1475。スペースグレイまたはシルバーのカラー、16/32/64/128 GBの構成で展開されています。
iCloud Lock Resistor Removal
Can I in fact remove resistor r1506 and revert it to a wifi only model and update it with the wifi firmware? I'm using the DNS bypass but it's just not enough. Word to the wise if someone sells you an iPad at 1% check to see if it's locked first do t wait til you get home
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
4件の回答
ベストアンサー
If the deal is to good to be true, 99.9% of the time it isn't!
See the TV ads about Dealdash.com. They tell you they bought all this stuff for pennies on the dollar, right. What they don't say is how much money was spent on bids. Usually $0.60 per penny bid. That's $60 for each dollar bid. Yes they ended up buying it for $60 but they actually sold it for $60 x 60 or $3600 plus the $60.
Oh, look at the print on the ad that says these prices are not typical!
Don't believe me, here's a testimonial: https://www.youtube.com/watch?v=sm2Y6on_...
このアンサーは役に立ちましたか?
スコア 5
6 件のコメント:
Looks like that could work I just can't tell where they went to do it.
さんによる 共有
All the hardware solutions available to remove iCloud lock by tricking the iPad is via here only for 3G models:
http://pasha4ur.org.ua/articles/difdevic...
さんによる 共有
Can you restore the ipad back to cellular?
さんによる 共有
Abdul I suggest you start a new question and give us specifics of your problems.
さんによる 共有
how to icloud unlock my ipad air 2 now help
さんによる 共有
1以上のコメントを表示
コメントを追加
Model selection is coded into the board factory data, you can't just remove something to trick it into believing it is some other models. Otherwise we can convert thousands of iPhones with dead baseboards(error-1) into iPod touches.
このアンサーは役に立ちましたか?
スコア 4
6 件のコメント:
So can I get a new board and swap them or not? Do you have any advice?
さんによる 共有
A new board is a new device, it's too expensive to swap.
さんによる 共有
You are wrong. You have to remove GSM resistor and flash the ipad with non GSM ipad model. After it loads up it will be detected as a completely different ipad with different model number
さんによる 共有
you are right , im actually tryin to turn recycled old iphone 5-6 into ipod by desactivating gsm serial number that will automaticly be detected as an ipod or wathever , i know this resistor bypas are real because ive actually already done it on a ipad a1452 i think , just asked myself if its also possible to do the same tricks on iphones , but need scheematic
さんによる 共有
@Murad Ismayil yeah the next serial number after removing resistor is n/a
さんによる 共有
1以上のコメントを表示
コメントを追加
If you want to ask :" I have An Ipad WIFI/LTE Icloud Locked, because I forgot to go to https://www.icloud.com/activationlock/ before I bought it, can I transform it to a Wifi only device just by removing one transistor ?" , the answer is yes.
Check this link :
http://forum.gsmhosting.com/vbb/f631/byp...
Just go directly to link dedicated to your model.
Pay attention : It's ok for All Ipads until the Ipad Air. Much more complicated for Ipad Air 2 Lte and probably for Ipad Pro. For Ipad Air 2 Lte the opéartion on the motherboard is siple too, but once you have restored your device as Wifi device, you will notice that you can't have any Wifi/buethooth connectivity. To fix this issue you will have to jailbreak and then to go to Cydia to install the missing parts of your IOS that enable you to have the Wifi/Bluetooth connectivity.
But apparently you have an Ipad air so, it's Ok.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thid hardware methond STILL works, but only usefull on older ipads, who can NOT run ios 11 or later, so NOT working anymore on Air, Air 2, Mini 2 etc.
さんによる 共有
there are method for all ipads, even ipad pro
さんによる 共有
コメントを追加
iPad Air r1506 resistor removal will not work if your iPad is on ios 11 or higher as this exploit has been patched, had i known this or read up abit more before doing so would probably saved me from ruining a perfectly good ipad air. Not worth doing this anymore.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brandon さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 121
今までの合計 33,831
