Where to locate the gps antenne
Does Anyone know where the GPS antenna is located in a HTC One m9
And also where it connects to the metal backplate..
Thank you very much for your answers
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
unfortunately it is under the ear speaker housing and there are several gold contacts under the daughter card on the top of the phone....
Very hard to get to, must use heat to remove, and very easily damaged. I know I am currently looking for the part. Which doesn't exist anywhere. But found on some replacement lcds for sale.
このアンサーは役に立ちましたか?
This ribbon cable antenna also is used by bluetooth.
Does anyone have a picture of the contacts for the GPS antenna? From what I see, it's not in the same position as on the M8. I have a M9 with a new frame and screen, and everything works except GPS.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,479
