メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
Plasma tv with sound but no picture
I have a 65" Plasma Samsung TV that is only 3 years old and one day the screen just went black. There is sound and no cords were unplugged or loose but the picture was completely lost. There are indicator lights that it's working obviously since we still have sound but not sure where the picture disappeared to.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Jamie Russell what exact model is your TV?
さんによる
コメントを追加
2件の回答
最も参考になった回答
I have a 43" plasma that had the same problem. After experimenting with several boards I found that the Y sustain board was bad. It cost less then $70.00 to replace. Again, check out the videos available on You Tube; I call it You Tube University. You will find videos relating to Samsung Plasma tv's. Since they are mo longer making plasma tv's you might want to hold on to the one you got. Believe me you can fix it for less than a new comparable set.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Maybe the monitor is dead. It should be the time for you for buy a new one. I strongly not recommend to fix it because it's pretty hard if it's a superslim tv. most of the parts are soldered and not easy to take apart if you don't have any experience.
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
回答を追加する
Jamie Russell さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 13,275
