メインコンテンツにスキップ
The Canon PowerShot A470 is a 7.1 megapixel digital point-and-shoot, announced January 2008.
14回答 すべてを表示
Lens will not retract hence the camara is now unusable
I changed the batteries as the old ones had run out, once I replaced the battery the lens would not retract. It states on the windows shut off camera and try again yet all I get is a strange whirring noise from the lens as if it is trying to retract but something is stopping it.
I have not dropped the camera it is only a year old and hardly used it. HELP as this was my 40th birthday present from my sister.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
If it was working before the battery change then I suspect something is wrong with the batteries. Remove them and install a fresh set being very careful of the battery polarity and make double sure they are the correct type. If you are still having problems get back to us. Good luck.
If you need it I am including a link for the manual.
http://www.retrevo.com/support/Canon-A47...
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
さんによる
The above answer is wrong. The problem is definitely NOT the batteries!
さんによる
The link to the "manual" is useless as well. The solution to a jammed lens is not covered by the Quck-start Guide or the User Guide from the manufacturer, which is provided by the link. This is certainly a common problem with this otherwise fine Canon camera. If I can find an answer, I'll return to post same, but haven't found an answer anywhere as yet.
さんによる
コメントを追加
回答を追加する
Lisa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,509
