メインコンテンツにスキップ
2015年Amazonから発売されたハイエンドFire OS 5タブレットです。10.1インチHDディスプレイとMedia Tekクワッドコアプロセッサを搭載しています。
20回答 すべてを表示
Why am I getting constant random ads?
I keep getting ads every 10-15 minutes and they're just now popping up. It doesn't matter if I'm in an app or on the home screen, they're always the same ones and if I click on it leads to nowhere and heavily slows the system for a while. Please help, I don't know what to do to fix it. I don't know if it's a virus or what, or if it's worth having a professional look at.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
I don’t want to restart because I will loose my stuff on my games what do I do now?
さんによる
My mom had same issue and I went to Apps & Notifications than look for Recently Opened Apps press see all apps and look for the apps that are causing trouble and press one at a time to uninstall them and like for my mom's Kindle Fire HD 10 that where causing trouble where Blood Pressure, Game Paradise, Classic FreeCell, and The Study Bible and funny thing is my mom does not read the bible and idk how it got on there and only once did I see it pop a video ad for a split sec and so far it seems fine expt now got those apps on home screen and I don't know what to do with them the ones causing trouble and hope this helps.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hey Michael,
When exactly did this start happening? Did you happen to install a new app around the same time that it started happening? As far as I know, Amazon only shows their ads on the lockscreen of Kindles with "Special Offers", and not on the home screen or in apps. I would try uninstalling your recently installed apps to see if that fixes the issue. If that doesn't help, I'd recommend trying to factory reset your tablet. This will reset your Kindle to how it was when you first got it, which should wipe away those advertisements.
このアンサーは役に立ちましたか?
スコア 5
13 件のコメント:
It started about a month ago, I knew there were ads on the lock screen but I thought it was weird when I randomly started getting these. The only app that I had downloaded at the time was Pandora, so I will try and get rid of that. Thank you for the advice, if that doesn't work I will try resetting it.
さんによる
Also note that Amazon "displays" ads in the notification area. They are typically items on sale in the store and from the offers section of your Kindle. They can be swiped away and cleared touching "clear all" just below your notifications. Also there are "no root" side loading solutions like at http://bit.ly/1m5fZfz , that will also remove Amazon only ads.
さんによる
Same thing is happening on my fire hd - only every 10-15 seconds it starts up displaying adds for new apps.
さんによる
how did you get rid of them paul
さんによる
This is happening to my Fire HD 10 every 10secs. I can't even get into device settings because it's constantly popping up
さんによる
8件以上のコメントを表示
コメントを追加
回答を追加する
Michael Langlois さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 73
過去 30 日: 490
今までの合計 16,120
