メインコンテンツにスキップ
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
20回答 すべてを表示
Digitizer does not work
Hi have changed the back light IC on the logic board. The back light issue is solved after replacing the back light IC but like always it is some or the other with ipads .
After hooking up everything the touch doesn't work, I have used 5 different digitizer to see if it is digitizer issue but neither one works and I dont know what could have happened .
Please suggest.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
[image|806990] I hope this will work
さんによる
コメントを追加
4件の回答
ベストアンサー
I suggest you knocked something off the board or used too much heat or damaged the connector. Look for missing components, balls of solder which do not belong, and/or any type of visible damage.
Next look at the schematics and troubleshoot touch circuit.
EDIT:
@touchwireless in the red circle most to the right in your picture, there seems to be a small component, possibly a resistor bridging two capacitors C3106 and C3108. Those 2 caps are on an important line shooting out from a touch IC. Remove that component and see if that solves it. Unless it is an artifact from the picture...
Here, that small guy in the middle of this circle, the only vertically positioned component:
このアンサーは役に立ちましたか?
スコア 2
12 件のコメント:
I am not good at soldering this is something I am trying to do and this is freeking me out
さんによる
what if i have used too much heat will the ipad still turn on ?
さんによる
It should, so that you be careful. If you apply unnecessary amounts of heat to remove the shields, you kill the phone. Practice with scrap iPhone 6 boards first. They are a special breed when it comes to shield removal.
さんによる
how should i know if thats the overheat issue
さんによる
is it fixable? if not I ruined the customers ipad
さんによる
7件以上のコメントを表示
コメントを追加
here is the pic for the logic board I worked on
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'll look at my schematics and get back to you. It does seem like you bridged something unless this is due to the bad image quality.
Can you add a high-resolution close-up picture of the area circled in red?
さんによる
コメントを追加
Heading text
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I hope this will work for you Rany
さんによる
Yes something is not right. You seem to have a component shorting two caps. They are on the same line, but it could be shorting them to ground and causing this. You need to remove it.
さんによる
コメントを追加
here is the picture marked with "A" and "B" could you please tell me which one to remove?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
@touchwireless check the picture I added last.
さんによる
Thank you I will update one I do this
さんによる
コメントを追加
回答を追加する
Touch Wireless さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 9
今までの合計 492
