メインコンテンツにスキップ
Repair information and troubleshooting for the HP Compaq Presario C700. This is a budget laptop made in 2008 as part of the Compaq Presario series of notebook computers.
22回答 すべてを表示
wont power up with power plugged to it
with the power cord plugged in the light around the plug doesnt come and the laptop doesnt come on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
ok..here it goes for the whole world..
The problem was that PQ1 was bad. Is located next to the PCN1 "where the power jack connects to the motherboard next to the memory". PQ1 is a P-Channel PowerTrench MOSFET P#: FDS6675BZ. you have to replaced it and the problem has to be solved.
one important thing is that if your not qualify to do this kind of job..you have to pay for somebody else to do it...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
DC-Jack needs repair
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have a C700 that had this same problem except it was the PQ2 chip. I tried to replace it without success. I had read others having luck just bypassing the chip with a jumper. I tried this and the laptop has been running fine now for a couple of months. I would recommend using the correct replacement if possible.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Kindly define that how and where to place jumper to bypass the chip.
さんによる
コメントを追加
回答を追加する
mike ward さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 4,271
