メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
20回答 すべてを表示
My phone isn't turning on and does not charge
my phone's run outta battery and when i was putting it to charge it fell
there wasnt any crack as such but it wont charge and is completely dead and won't turn on
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
The charger port on the Galaxy S III can sometimes break , especially after extended use. In order to identify your problem, start small and work your way up.
First, try using a new (or at least different) charger cable for your phone, any android charger would do the trick.
  • Sometimes the charger simply doesn't seat correctly in the port, so if a different charger works on your phone, inspect your old on for any weakness in the cable, check that the securing tabs aren't broken, check that the 4 pins aren't bent or missing.
If a new charger doesn't do the trick, test the battery. Take the back off of your phone by lifting under the indentation of the phone and then remove the battery completely.
  • For more detailed instructions, check out this tutorial here. Flip the phone over and plug in the new charger to the phone and to a power source.
If your phone turns on without the battery inside of it, then you just have a bad battery, which means you just need to buy a new one and replace it.
If not, your issue is most likely with the charger port of the phone on the motherboard itself. There is also a guide to replace your motherboard here, but this is a bit more advanced and requires some extra tools.
Samsung Galaxy S III Batteryの画像
ガイド
Samsung Galaxy S III Battery Replacement
難易度:
簡単
5 minutes
Samsung Galaxy S III Motherboardの画像
ガイド
Samsung Galaxy S III Motherboard Replacement
難易度:
簡単
20 - 45 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
andiewest1234 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 134
