メインコンテンツにスキップ
Sony Cyber-shot DSC-W150 is a 8.1 megapixel point and shoot camera with a 2.7" LCD display.
camera turns on but screen back light not working.
My sister spilled water into her purse and some got on her DSC W150 camera. It wouldn't even turn on for days. After the internal battery discharged the camera was able to turn on but the display had no picture.
I took the camera and put it under a lamp and noticed that the display was actually on but the back light was dead. I hit the 'display' button of course to confirm this by cycling through the LCD on / off, and other functions like show histogram to confirm that the display wasn't simply turned off by default.
It appears that the camera functions fine, lens opens, zooms, and that I can read and navigate through the menu screens, under direct bright light. But I have no back light to make this camera useful. For example if the battery dies I have to set the date up upon boot up. So there's no way to switch to camera mode to skip this step.
So I don't know if I should replace the whole screen assembly (which I know the part #) or just the back light (unsure which part causes issue).
The other thought I had was that maybe the auto dimming light sensor was causing the LCD brightness all the way down.
What do you guys think I should do?
Thanks..
Tom
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
Yeah I still have the issue. I just took a break from the forums.
さんによる
I am facing the same problem .. can anyone please help..
さんによる
Jagjit Dhaliwal, which camera do you have and what exactly is the problem you encounter? What have you tried to fix it?
さんによる
I'm experiencing the same problem the cameras working fine but the LCD light is off it's a PowerShot Canon SX 740
さんによる
コメントを追加
3件の回答
ベストアンサー
Id just get a new display, but before I did that I would see if I could open it up and locate the display connector (if there is one) then make sure everything is dry and connected properly. I would also try a hard reset (opening the battery case while it is running). I hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It does sound like your backlight is out. The backlight is part of the LCD. Double check your ribbon cable and your connector. If everything looks okay, I would replace the LCD. The service manual for your teardown is available for your download on my fileserver It will also allow you to further trouble shoot your camera. Good luck and let us know how it is progressing.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
my camera is working all right but i am not able to see the pictures clicked by me. my camera shows accessing
さんによる
コメントを追加
I'm literally having the same problem right now and I'm wondering what I should do
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
So...I just got as brand new lcd screen for my Sony cyber-shot DSC-H10... and the screen works but I have no back light. Can anyonehelp me?
さんによる
コメントを追加
回答を追加する
Tomo さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 21
今までの合計 11,465
