メインコンテンツにスキップ
ディスク・スペースが足りないですか? バックアップソリューションが必要ですか? 外付けドライブは、オフィスや外出先で追加のストレージを提供します。 このページで修理する方法を学べます。
20回答 すべてを表示
Does anyone know how to open up this case?
I've got a G-Tech G-Drive Mobile USB 3, and the USB connector port has broken clean off the circuit board inside the unit. I've got a replacement drive and I've got SATA to USB cables to transfer the data off the internal drive. Problem is that there are no screws on this casing! I've got a putty knife and various soft and hard pryers and spreaders, but before I go hacking at the case I was hoping one of you fine folk might have already had at one and can give any pointers as the best and least destructive way to get to the internal drive??
Many thanks!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
6 件のコメント
Hey, how did you get on with this?
さんによる
Same issue here, did you manage to get the case off?
さんによる
same issue here! and it's brand new. how do i get the data off!?
さんによる
Its pretty easy to take apart. Just used a letter opener to pry off the plastic ring around the housing. If the USB is what was damaged, your data is safe! The hard drive inside the housing converts Sata to USB and your Sata connection is almost certainly undamaged.
さんによる
Same issue. So it's a ring, not a lid? The black band is a separate part? I'm having trouble figuring out how to hold on to it in order to pry the ring off.
さんによる
1以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
Sorry I missed this question.
Check out this tear down video and see if I got the correct drive:
https://www.youtube.com/watch?v=YTGFlmAs...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
no not even.
さんによる
This other video looks closer to the OP: https://www.youtube.com/watch?v=cSq8ZppZ...
That gave me courage to tear into my GDrive mobile case. The "ring" is pretty beefy plastic, with "reverse clips"holding the tops and bottoms on with 10 slots around the edge of the bottom shell. (2 slots at each end and 3 slots on the sides.) Scratched up my enclosure a bit getting it open. Now I can't figure out how to get the drive out. Is it glued or taped?
さんによる
コメントを追加
最も参考になった回答
Hello,
I found this question while I was looking for an answer for the same drive you have a USB 3 GDRIVE mobile. I got mine open by using a couple of plastic knives from Wendys restaurant. I forced the tip of the knife between the edge and the bottom cover. Start on one of the long sides near the corner on the USB end of the drive case. Those two corners don't have catches and will be the easier to get it started opening. Once you get it started keep working your plastic knives around the sides working them loose. Really none of the corners have catches but the two on the USB end have a larger area without catches.
Hope this helps! You could use s spudger, but I have lots of plastic knives and I wanted to possible reuse the case it the circuit board is still good.
Enjoy!
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
Ok now that I have the bottom off, I found that the drive is held in there by screws in the side of the drive and the edge has little cups that the screws fit into. It is holding it really solidly. I also used the plastic knives the pry the edge out so it released the drive. It is a real pain! But thats how I got the drive out of the case.
さんによる
I created an account just to say thank you, man. This is the real answer and I hope you get credit for it.
さんによる
コメントを追加
hi,
have the same problem, this may be silly, but what do you do once you prised the case open to get access to the drive?
thanks
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Good question, you can buy a sata to USB adapter. Then plug it into your computer and remove the data off the drive.
さんによる
コメントを追加
Here's a picture of the inside of my GDrive Slim Mobile case. Note the reverse clips around the edge.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tom Moreno さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 60
過去 30 日: 206
今までの合計 30,637
