メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
How can I stop my phone from running low very quickly?
My galaxy III has starting running the battery low very quickly {6-7 hours}.
I bought a replacement battery but that was not the problem.
I would appreciate help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Turning off gps location and WiFi will help reduce the draw on the battery.You can also go into setting>more>battery and here you can see what is using all your battery. it shows what apps are running and how much power there running.you may also want to shut off running apps by holding down the home button (while on the home screen )and all the running apps will be displayed. to stop them simply swipe them to the left, you may also want to check your power saving mode. This is found by going to settings >My Device>power saving mode. hope this helps
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
Thanks Jim, i appreciate it. Most of the things i had already done but "you may also want to shut off running apps by holding down the home button (while on the home screen )and all the running apps will be displayed. to stop them simply swipe them to the left" seems to have helped.
Thanks again
さんによる
コメントを追加
回答を追加する
Rod Billett さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 113
