メインコンテンツにスキップ
Released in 1998, the FDL-220R Watchman is a portable television and radio with a color LCD screen. It is the last Watchman model produced by Sony.
3回答 すべてを表示
Why does my TV screen show a vertical red line/static?
When I switch my Watchman into TV-mode, I can only see static and a vertical red line that moves across the screen. How can I fix it to get a clear picture?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
The red line going across the screen is the device notifying you that it is trying to receive a signal. The antennas may have gotten damaged over time and the device is not able to pick up a signal. I had an older watchman like this several years ago, and the red line is the device seeking reception and not finding a strong signal.
*edit* Forgot to mention that the US has discontinued analog television signals since 2009, so you most likely will never again receive reception.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Madison Dalton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 1,242
