How to reset bios password
How to reset the laptop password?
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
greg, the password is stored in NVRAM, not in the regular CMOS settings. Removing the battery will not remove your password. For that you can either contact Dell or use your service tag to get the password.
このアンサーは役に立ちましたか?
its doesnt show even where to enter the passsword ... why?
Salvis Krofts I am not sure I even understand your question. You really should elaborate on what you are needing.
take the motherboard battery out, for like a minute or so. That will make the bios run out energy and will make you load bios defaults. you will need to set time and date correctly after that.
このアンサーは役に立ちましたか?
hello,i have the same problem and i took the bios battery for days but still asking for the pasword
The normal answer is to use service tag or administrator password...No answer for both even after trying F2 or F12. The 2 numbers on the back don't work.
hey i have dell inspirion 1525
my hard disk block with password
system Number :DPWN4BS-595B
PLEASE ANY ONE HAVE SOLUTION
PLEASE SENT ME MAIL @ vijaymhaske77@gmail.com
このアンサーは役に立ちましたか?
8CSLK3-595B dell inspirion 1525
marouanrahire61@gmail.com
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 6,096
