メインコンテンツにスキップ
The N95 8GB is a revision of the N95, with a larger screen, 8GB of internal flash storage and larger capacity battery.
2回答 すべてを表示
black screen of death for a Nokia N95 8GB?
I fully charged my nokia - all buttons light up and keys beep and are responsive BUT the screen is black and appears dead. I have a dead screen.
I have googled this issue and a number of others have had the same issue in the past but I cannot find a fix?
Does anyone in cyberspace have a practical DIY fix please? thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Rick Cowan, the only solution I have come across on multiple forums is by placing a jumper across the capacitor C4410. Of course you have to make certain that your LCD assembly is working properly. The service manual further more suggest to check L1150 R1151, C1156 and C1155 visually. make sure that those parts do not look charred or are missing. Let us know how good your skills are with microsoldering and measuring SMC's. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I also have this problem. I opened the phone up and the problem seems to be the connector from the display that breaks from sliding the screen and time. I think you should buy a new screen asambly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rick Cowan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 2,784
