メインコンテンツにスキップ
GSM iPad 2は16、32、64GBの容量オプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1396。修理作業は複雑で、ヒート(熱)を当ててこじ開ける作業が必須です。
20回答 すべてを表示
ipad wont slide off after I replaced the wi fi cable
i recently replaced my ipad 2 screen and accidental messed up the wifi cable,i have placed an order for a new one however i also have an issue with it not sliding on it starts up ok it just wont let me slide to unlock it ,could that be caused by the wifi? when i plug it into my laptop it says i must enter the passcode on the ipad i never set it up using the passcode.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
You have either a defective screen, or you have mis-installed your screen. Check to see if the black plastic connector is latched on both sides of the digitizer flex.
Not related to WiFi.
If you have iOS 7--the setup wizard prompts you for a passcode at set up. You may have typed one in just to get past that screen.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
thank you i just ordered another replacement screen from a different company this one has the power button and stickers already on it im praying this works thank you again for your help . i cant turn it off without the slide button and was wondering its on and i know not to touch the lcd with my fingers if it was the screen would the lcd work? is there a way to test if its the screen?
さんによる
If you can see the image, the LCD works.
さんによる
thank you so very much for your help it is fixed the replacement one i received didn't work,the second one worked great.
さんによる
コメントを追加
回答を追加する
lisa0201 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 114
