メインコンテンツにスキップ
The PowerShot SD850 IS Digital ELPH is a digital camera with a 8.0 Megapixel CCD, and a 4x Optical Zoom. The item was released in May of 2007.
SD950 IS disassembly differences from 850
What differences will be in countered between 850 guide and my 950 IS. I got sand in the Len mech won't open.
Big question is can the lens mech be cleaned and how?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント:
your camera is a PowerShot SD950 or a Digital Elph/IXUS 950 IS?
さんによる
thanks for asking - Powershot SD950IS
さんによる
コメントを追加
1 件の回答
Hi Joe,
I just used this guide to take apart my 950 IS to swap out the screen from another one. There really isn't much different, one or two less screws to take out and the cables for the LCD look a little different but it's essentially the same process to remove it. Just be sure to keep track of which screws go where and you should be fine.
I bought a broken 950 IS off ebay to use for parts so I may put that back together and create a guide for disassembling that at some point in the future.
Cheers,
Martin
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 509
