メインコンテンツにスキップ
The Motorola Droid 4 is a smartphone made by Motorola that was released with Android 2.3 and is upgradeable to Android 4.1.
20回答 すべてを表示
Touch screen unresponsive when keyboard is slided out
So that is my problem, when I slide out keyboard, touch screen or buttons under it (home, back, etc). Become unresponsive, screen works great no distortions of any way in screen and as soon as I slide keyboard back in it becomes responsive with any issues.
Could it be that some kind of flat/flex cable needs replacement?
Also... if for example I click on icon and then slide keyboard in. It will react on the click. Like keyboard is blocking the the touch input.
Another thing, I was tinkering with input settings and once I made them work both, but when I rebooted phone I'm stuck with the same problem.
UPDATE: I just did a factory reset, problem persists so it might have been coincidence that it started working after my tinkering.
So... please advise me on both software and hardware solutions for this problem.
It uses Android 4.1.2, not rooted, but thinking of doing it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Very strange. My only idea would be to replace the flex but i have to admit i haven't seen anything like that in a long while. good luck
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Could this be the part in question?
http://www.etradesupply.com/motorola-dro...
It's the only part I found that could be it.
Thank you!
さんによる
Yup! If the flex is the problem then that would be your part! Just be careful. pretty hard repair and if its the same phone im thinking of, things get pretty hairy once into the top portion of the phone. Good luck friend!
さんによる
コメントを追加
回答を追加する
alexxandar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,092
