メインコンテンツにスキップ
iMac Intel 21.5" EMC 2428 Teardown
手順 16を翻訳中
英語
日本語
手順16
iMac Intel 21.5" EMC 2428 Teardown: 手順 0、 2の画像 1 iMac Intel 21.5" EMC 2428 Teardown: 手順 0、 2の画像 2
  • iMac 21.5" EMC 2428 Repairability Score: 7 out of 10 (10 is easiest to repair)
  • The front glass panel and LCD are quite easy to remove for accessing all the hardware underneath.
  • RAM, hard drive, and optical drive can be replaced with relative ease, as long as you don't mind taking out the LCD (for the drives).
  • Limited use of adhesives (pretty much all the fasteners are mechanical) make disassembly pretty straightforward.
  • Replacing the CPU and GPU is possible to do, but you need to remove the logic board from the computer.
  • Removing the logic board is a pain, since you have to disconnect a bunch of connectors, and wiggle it out of the machine.
  • Making the LCD and glass spotless when reassembling the machine is nearly impossible. (compressed air is useful when trying to remove dust from the display or glass panel)
  • Like being able to see the guts of your machines? Check out our iPhone 4 transparent rear panel!
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります
