メインコンテンツにスキップ
Showing how A Fitbit Charge HR is taken apart
必要な工具と部品
ツール
この分解は修理ガイドでは ありません。 お持ちのFitbit Charge HRを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Fitbit Charge HR Teardown, Remove Screws: 手順 1、 1の画像 1
    • Take the 4 Screws out of the Sides you will need a T3 star Screw Driver
  2. Fitbit Charge HR Teardown: 手順 2、 2の画像 1 Fitbit Charge HR Teardown: 手順 2、 2の画像 2
    • You Pry out the Main board you can see the Metal Hooks
  3. Fitbit Charge HR Teardown: 手順 3、 1の画像 1
    • You can Then pull out the Screws from around the Screen
作成者
1人の作成者と共同作成されました。
Bradley Nelson
メンバー登録日: 03/08/16
56 ポイント
1ガイドが承認済み
8 件のコメント
Can the battery be replaced?
Rick - 返信
Mine was just over a year old (barely out of warranty) when it died. The Fitbit folks were kind enough to replace it anyway once I expressed my displeasure. I'd haggle with them a bit before going the DIY route but I'm definitely keeping my old one for spare parts. Hopefully someone will point out an aftermarket battery source before I need to do that.
fragmasterflash - 返信
The screws in mine were Torx T-2, not T-3.
Jake McIvor - 返信
The button is stuck in my ChargeHR. I bought the T3 screwdriver and it is too big. Either the screws are T2 or my screwdriver is too much imprecise.
Anyone fixed a stuck button?
Anderson Maciel - 返信
it definitely not T3 must be T2
Marc Frederick - 返信
No, a charge hr is a t3
eric hicks - 返信
Definitely not T3 screws, bought a T3 just for this - its too big!
martin - 返信
Does anyone know where to get a spare band?
RoadKill - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 24,068
