メインコンテンツにスキップ
This guide shows how I disassembled the lens in an attempt to clean it.
必要な工具と部品
ツール
もっと見る
この分解は修理ガイドでは ありません。 お持ちのCanon EF 35-80mm IIIを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Canon EF 35-80mm f/4.0-5.6 III Teardown, Remove the info sticker ring: 手順 1、 1の画像 1
    • The glue is quite sticky - the sticker ring will never look the same again.
  2. Canon EF 35-80mm f/4.0-5.6 III Teardown, Removing the Front Lens Assembly: 手順 2、 2の画像 1 Canon EF 35-80mm f/4.0-5.6 III Teardown, Removing the Front Lens Assembly: 手順 2、 2の画像 2
    • Unscrew the three JIS #000 screws that holds the front lens assembly to the rest of the lens.
    • It seems this partially disassembled lens can be used as a macro lens - I didn't try.
  3. Canon EF 35-80mm f/4.0-5.6 III Teardown, Separating the front and back halves: 手順 3、 1の画像 1
    • Remove the rubber zoom ring. This exposes three JIS #000 screws and their metal collars.
    • Take care not to drop the metal collars - they are like washers.
  4. Canon EF 35-80mm f/4.0-5.6 III Teardown, Disconnecting the flex cable: 手順 4、 1の画像 1
    • Pull out the connector of the flex cable vertically while supporting the circuit board (I used a plastic spudger to push down the circuit while pulling the white connector). To insert it back, simply push it back into the slot. Note the orientation of the connector (Take lots of pictures)
    • Note the black plastic pillar - the white focusing gear (obstructed in this shot) from the focusing ring needs to go back inside this during re-assembly. It's a little tricky.
  5. Canon EF 35-80mm f/4.0-5.6 III Teardown, Removing the lens/Diaphragm unit: 手順 5、 1の画像 1
    • Unscrew the three JIS #000 screws to release the zooming ring barrel.
    • Be careful not to damage the metal brush. It can be removed and re-installed easily.
  6. Canon EF 35-80mm f/4.0-5.6 III Teardown, Freeing the power diaphragm unit: 手順 6、 1の画像 1
    • Once the barrel is freed, the rest of the assembly comes apart once the pieces are rotated - they are 'nested' within helical tracks inside each 'shell'
    • Before you disassemble it, note carefully how each 'layer' is nested within the next one. Otherwise it will take a lot of trial-and-error to put it back.
    • The focussing ring assembly also 'drops out'. To re-assembleit, align the 3 tabs in the barrel with the slots in the inner helicoid (inner part of the focussing ring), then turn it 45º.
    • During re-assembly, ensure that: 1. the ribbon cable doesn't get snagged. 2. the white focusing gear needs to sit into the black pillar (highlighted in step 4)
    • Useful document: Parts Catalog for Canon EF 35-80mm III Lens
添付文書
作成者
4人の作成者と共同で作成されました。
Lawrence Lau
メンバー登録日: 04/24/12
151 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 46
今までの合計 1,933
