メインコンテンツにスキップ
iRobot Roomba 4100 Battery Pack Replacement
Scott Leonard
Scott Leonard とその他 13 人の作成者
最終更新日: January 28, 2022
1 - 2 分
とても簡単
This guide explains how to replace the iRobot Roomba 4100 battery by giving you the necessary instructions. The Roomba battery may need to be replaced if your Roomba will no longer charge or if the Roomba no longer powers on. Depending on the amount of use of the Roomba, you may need to replace the Roomba if power issues are consistent and are not fixed with a simple battery replacement. Replacing the iRobot Roomba 4100 battery will solve the power issues and allow your Roomba a stronger and longer lasting charge. To repair your iRobot Roomba 4100 battery their are no special skills or prior knowledge needed. The battery is a vital part of the Roomba, and for it to be operational the battery should be in good condition for proper function.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. iRobot Roomba 4100 Battery Pack Replacement, Battery Pack: 手順 1、 1の画像 1
    • Turn the Roomba upside down to be able to see the yellow battery pack.
  2. iRobot Roomba 4100 Battery Pack Replacement: 手順 2、 2の画像 1 iRobot Roomba 4100 Battery Pack Replacement: 手順 2、 2の画像 2
    • Remove the battery by placing your fingers into the two holes and firmly press your fingers against both sides of the battery.
    • Lift the battery directly up and out of the device.
  3. iRobot Roomba 4100 Battery Pack Replacement: 手順 3、 1の画像 1
    • Line up the replacement battery’s larger tab side with the larger tab hole and the smaller tab side with the smaller tab hole.
    • Insert the replacement battery into the empty space and firmly press down onto the battery until two audible clicks are heard.
終わりに
Your iRobot Roomba 4100 is now ready for use.
2 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
Scott Leonard
メンバー登録日: 10/05/10
445 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 20-6, Maness Fall 2010 Cal Poly, Team 20-6, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S20G6
2 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 13
過去 30 日: 19
今までの合計 8,482
