メインコンテンツにスキップ
iPod Nano 4th Generation Outer Case Replacement
Walter Galan
Walter Galan とその他 3 人の作成者
最終更新日: August 23, 2022
1時間
難しい
Use this guide to replace a worn anodized aluminum outer case.
必要な工具と部品
ツール
もっと見る
  1. iPod Nano 4th Generation Outer Case Replacement, Glass Panel: 手順 1、 2の画像 1 iPod Nano 4th Generation Outer Case Replacement, Glass Panel: 手順 1、 2の画像 2
    • Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
    • Pry the top bezel off the adhesive securing it to the display retainer.
    • At this point the hold switch slider is free and may fall. Be careful not to lose it.
  2. iPod Nano 4th Generation Outer Case Replacement: 手順 2、 1の画像 1
    • Remove the hold switch slider from the top of the Nano.
  3. iPod Nano 4th Generation Outer Case Replacement: 手順 3、 1の画像 1
    • Remove the two angled Phillips screws from the two corners of the display retainer.
    • These screw heads are extremely small and easily stripped.
  4. iPod Nano 4th Generation Outer Case Replacement: 手順 4、 1の画像 1
    • Insert an iPod opening tool between the outer case and the display retainer.
    • Use the tool to slide the display assembly out of the case slightly.
    • Do not rotate the display retainer about the top edge of the display, as it is attached to a thin steel bracket that is easily broken.
    • Do not forcefully remove the display retainer, as the hold switch cable is liable to snap.
  5. iPod Nano 4th Generation Outer Case Replacement: 手順 5、 1の画像 1
    • Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
    • Do not put unnecessary tension on the very thin display data cable.
  6. iPod Nano 4th Generation Outer Case Replacement: 手順 6、 2の画像 1 iPod Nano 4th Generation Outer Case Replacement: 手順 6、 2の画像 2
    • With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
    • Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
  7. iPod Nano 4th Generation Outer Case Replacement: 手順 7、 1の画像 1
    • Lift the glass panel out of the Nano.
    • Before reinstalling the glass panel, be sure to clean the face of the display and the inside of the panel as any dust or fingerprints will be annoyingly visible when the Nano is turned on.
  8. iPod Nano 4th Generation Outer Case Replacement, Display: 手順 8、 1の画像 1
    • Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
    • The hold switch ribbon cable is extremely fragile and easily broken. Work gently.
  9. iPod Nano 4th Generation Outer Case Replacement: 手順 9、 1の画像 1
    • Peel back the Kapton tape covering the display data cable socket.
  10. iPod Nano 4th Generation Outer Case Replacement: 手順 10、 1の画像 1
    • While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
  11. iPod Nano 4th Generation Outer Case Replacement: 手順 11、 1の画像 1
    • Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
    • Be careful not to rip the display data cable.
  12. iPod Nano 4th Generation Outer Case Replacement: 手順 12、 1の画像 1
    • Pull the display out of the Nano, minding the hold switch cable that may get caught.
    • As you pull the display out of the case, be careful not to break the hold switch cable.
  13. iPod Nano 4th Generation Outer Case Replacement, Logic Board Assembly: 手順 13、 2の画像 1 iPod Nano 4th Generation Outer Case Replacement, Logic Board Assembly: 手順 13、 2の画像 2
    • Insert an iPod opening tool between the bottom bezel and the dock connector.
    • Separate the bottom bezel from the adhesive securing it to the Nano and set it aside.
  14. iPod Nano 4th Generation Outer Case Replacement: 手順 14、 1の画像 1
    • Remove the three Phillips screws along the bottom of the Nano.
    • The slightly longer of the three screws belongs in the middle.
  15. iPod Nano 4th Generation Outer Case Replacement: 手順 15、 2の画像 1 iPod Nano 4th Generation Outer Case Replacement: 手順 15、 2の画像 2
    • Use an iPod opening tool to pry the aluminum dock bezel out of the Nano.
    • The dock bezel is very thin cast aluminum. To avoid breaking it, do not excessively flex it during removal.
  16. iPod Nano 4th Generation Outer Case Replacement: 手順 16、 3の画像 1 iPod Nano 4th Generation Outer Case Replacement: 手順 16、 3の画像 2 iPod Nano 4th Generation Outer Case Replacement: 手順 16、 3の画像 3
    • Use the flat end of a spudger to separate the battery from the adhesive securing it to the outer case.
    • The lithium polymer battery used in the Nano is very flexible. Try not to deform it excessively while separating it from the outer case.
    • Use the flat end of a spudger to push the logic board assembly and battery slightly out of the bottom of the Nano. Stop once it pops out a little bit.
  17. iPod Nano 4th Generation Outer Case Replacement: 手順 17、 1の画像 1
    • Use the edge of an iPod opening tool to peel the click wheel ribbon cable and its ZIF socket off the dock connector.
  18. iPod Nano 4th Generation Outer Case Replacement: 手順 18、 2の画像 1 iPod Nano 4th Generation Outer Case Replacement: 手順 18、 2の画像 2
    • Use the edge of an iPod opening tool to flip the ZIF cable lock up toward the headphone jack.
  19. iPod Nano 4th Generation Outer Case Replacement: 手順 19、 1の画像 1
    この手順で使用する道具:
    • Use a pair of tweezers to slide the click wheel ribbon cable out of its socket.
    • Before proceeding, be sure that both the click wheel ribbon cable socket and its cable are freed from the adhesive securing them to the dock connector and logic board.
    • Peel back the cable on both ends!
  20. iPod Nano 4th Generation Outer Case Replacement: 手順 20、 1の画像 1
    • Pull the logic board assembly out of the outer case, minding the hold switch and click wheel cables that may get caught.
    • When reassembling, ensure the click wheel cable is toward the front of the Nano and not in the grooves on the side. If it is in the groove you will probably cut it while sliding the logic board into place.
  21. iPod Nano 4th Generation Outer Case Replacement, Click Wheel: 手順 21、 2の画像 1 iPod Nano 4th Generation Outer Case Replacement, Click Wheel: 手順 21、 2の画像 2
    • Press down firmly around the perimeter of the click wheel to separate it from the adhesive securing it to the outer case.
    • This requires a good amount of force. Work slowly.
    • It may be helpful to use an edged tool to separate the adhesive from the click wheel on the inside of the Nano while pressing it down from the outside.
    • Remove the click wheel from the inside of the Nano.
    • Be careful not to let the click-wheel slide on the metal plate supporting it, as it will break the flat cable. Apply force perpendicular to the click-wheel.
  22. iPod Nano 4th Generation Outer Case Replacement, Outer Case: 手順 22、 1の画像 1
    • Outer case remains.
終わりに
12 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Walter Galan
701,132 ポイント
1,203のガイドは作成済み
3 件のコメント
Interesting
Where can I buy those outer cases?
Jay - 返信
What I have found is most are on eBay. I have been looking for a orange shell and can only find some cases.
Ad123re -
@jay9016 ebay ifixits store Amazon really all online shops
Appleiphone - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 52
今までの合計 29,722
