メインコンテンツにスキップ
iPhone7のWi-Fiダイバーシティアンテナの交換
必要な工具と部品
  1. iPhone7のWi-Fiダイバーシティアンテナの交換, ペンタローブネジ: 手順 1、 1の画像 1
    • 作業開始前にiPhoneバッテリーを25%以下まで消費してください。充電されたリチウムイオンバッテリーは、バッテリーに穴が空いた場合、引火や爆発の恐れがあります。
    • 分解を始める前に、iPhoneの電源を切ってください。
    • iPhone下部底面に留められた3.4 mmペンタローブネジを2本外します。
    • iPhoneのディスプレイを開口するとディスプレイ上の耐水性シールにダメージを与えてしまいます。再組み立ての際、接着シールを交換しなくても通常通り機能しますが、耐水機能を保てないことを留意ください。
    Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
    Cooper Chase - 返信
    Confirmed, the screws have a black ring seal around the head.
    rcheing - 返信
    Can’t get the display front
    Bernadette Pfeifer - 返信
    From personal experience, I highly recommend before doing this procedure or any other, that you do a backup of your phone (preferably local) in case your procedure goes south.
    ballina5ny - 返信
    I purchased the repair tools with the replacement battery from iFixit. The tools include a screw driver and three heads none were labeled 3.4 mm. I think the one that fit the pentalobe screws was labeled Y000. The guide should identify the screw driver head supplied by the kit not 3.4mm.
    Mark Lieberman - 返信
    in the iphone 7 replacement battery kit from iFixit, the screwdriver that fits the 3.4 mm pentalobe screws is labeled P2 (and not Y000)
    Jan-Tijn Oppermann -
    3.4 mm is the height of the screw and is not related to the screw driver code.
    Ahmad Vaziri -
    the screwdriver PH000 does not work i wasted two screws and now they dont have the 4 cross mark they are now a circle, i buyed it all from Paraguay and it doesnt work, had to assembly back the parts because i got stuck like i mention with some screws, well im just going to send to a professional to install, thanks
    Martin Frutos, Nuñez - 返信
    The bottom screws are Pentalobe, not Phillips.
    Bram Driesen -
    Before starting, I would recommend backing up your Iphone’s data just in case.
    Jon Moylan - 返信
    If you managed to make it to this section, just send the phone into apple for 50 + 6 dollars shipping. The ribbon cables on the screen are designed to break. I can literally twist on the rest of the cable and it won’t fall apart but there is a diagonal section where it snaps. This is the fault of apple and the fault of ifixit for misrepresenting the fragility of the cables.
    Ryan Huebert - 返信
    Had to reheat it a few times for a minute each with a hairdryer to get the seal to break after pulling and rocking the suction
    Cynthia Lamb - 返信
    I’m technically challenged. Is there a premier national service who can professionally install a replacement battery got my 7 +?
    Richard - 返信
    Do the screws come out in total?
    YVES THEUGELS - 返信
    They may come out or may not. If you loosen as much as you can and they don't come out you should still be able to pry open the bottom. Once you get the screen off you can then push the screws out from the inside.
    Anthony Falabella -
    Is it the P2 you should use for the bottom??
    YVES THEUGELS - 返信
    I heated the bottom of the phone with a hairdryer and then used a syringe to put a couple of drops of acetone directly into the bottom two screw holes. I GENTLY pulled on the screen with the suction cup and used the pry tool to GENTLY separate the screen. The sealant is applied around the entire display so be very careful pulling it off so you don’t break the fragile display cables.
    Anthony Scaminaci - 返信
    At first it was very difficult to open, per instructions. I used a heat/ice pack and nuked it for 1 minute. The pry tool wasn’t working so I carefully used my pocket knife to wedge the cover open. The rest of the procedure went well until I cracked the glass while trying to get the top right corner to pop off. Other than that mistake, all went well. Tip: before setting the new battery, attach the battery connector first and leave enough room for the taptic engine, or better yet, place the taptic engine before adhering the replacement battery. This way you’ll have a small gap between the two, whereas mine barely fit. Good job on hosting the video, Gwendyl.
    Klaus Preiss - 返信
    I love the fact that the screw bit and shaft are magnetic! I almost lost a screw and found it attached to the magnet.
    I used a heat/ice pack and nuked it for 1 minute. At first the display cover was very difficult to open with the pry tool, per instructions. The pry tool wasn’t working so I carefully used the blade of my pocket knife to wedge the cover open. The rest of the procedure went well until I cracked the glass while trying to get the top right corner to pop off. Other than that mistake, all went well. Tip: before setting the new battery, attach the battery connector first and leave enough room for the taptic engine, or better yet, see the taptic engine in place before adhering the replacement battery. This way you’ll have a small gap between the two, whereas mine barely fit because I placed it almost too low.
    Klaus Preiss - 返信
    I replaced the lightning connector assembly and reassembled. The old one did not 'click' into the cable and had corrosion inside, it needed the cable to be placed in a specific way to charge. The new part - does not recognize that a charger is plugged in at all.
    I backtracked the assembly - took it apart, put it back again - and find that every thing on the part works - the mic, speakers, taptic engine.
    The original problem with the cable still persists. Any ideas?
    H K - 返信
  2. iPhone7のWi-Fiダイバーシティアンテナの交換, iPhone 7の開口方法: 手順 2、 1の画像 1
    • iOpenerの下側端を温めると、ディスプレイに留められた圧着剤が柔らかくなり開口しやすくなります。
    • ヘアドライヤーもしくはiOpener を準備してiPhoneの下側端に約1分間載せます。下に付けられた圧着剤が柔らかくなります。
  3. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 3、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 3、 2の画像 2
    • 吸盤カップをディスプレイアセンブリの下部半分より下、かつホームボタンよりも上の位置に装着します。
    • 吸盤カップがホームボタンに重ならないように注意してください。重なってしまうと吸盤カップとフロントガラスの間に隙間が出来てしまい、しっかりと吸着することができません。
    • ディスプレイ全体のひび割れ程度が大きい場合、吸盤カップが上手く装着しないことがあります。透明な補強テープを使って表面をカバーしてください。もしくは吸盤カップの代わりに強力な梱包用テープなどを使用することもできます。それでも上手くいかない場合は、吸盤カップ上にボンドなどを付けて固まったら引っ張ります。
  4. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 4、 3の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 4、 3の画像 2 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 4、 3の画像 3
    • ディスプレイアセンブリと背面ケースの間に小さな隙間が出来るように吸盤カップで引き上げます。
    • スパッジャーの平面側先端を隙間に差し込みます。
    • ディスプレイを留めている耐水性のある接着剤はとても強力です。最初の隙間を作るためにかなりの努力が必要です。もし隙間を作るのが難しい場合は、スパッジャーを内部に差し込めるほどの隙間ができるまで、吸盤カップを上下に動かし続けてください。
  5. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 5、 3の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 5、 3の画像 2 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 5、 3の画像 3
    • iPhoneの下部端から左側に沿ってスパッジャーを動かします。
    • ディスプレイと背面ケースの間に出来た隙間を広げるために、スパッジャーをひねりながら動かします。
  6. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 6、 3の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 6、 3の画像 2 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 6、 3の画像 3
    • スパッジャーをiPhone下部端から左側に移して、下から音量ボタンとサイレントスイッチを通って上部に向けて動かしていきます。
    • ディスプレイ上部端をリアケース側から外さないでください。プラスチッククリップで留められているため、無理に外そうとすると壊してしまいます。
  7. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 7、 3の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 7、 3の画像 2 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 7、 3の画像 3
    • デバイス下側の右側角にスパッジャーの平面側先端を差し込みます。
    • ディスプレイアセンブリとリアケースの間の隙間を広げるためスパッジャーをひねりながら動かしていきます。
    • スパッジャーの平面側先端をデバイス右側から上部に向けてスライドして動かします。同時にディスプレイに留められた圧着剤をスパッジャーで切り込みます。
    • デバイス右側端に沿って付けられた、デリケートなリボンケーブルにダメージを与えないよう、留められた接着剤より内側にスパッジャーを差し込まないでください。
  8. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 8、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 8、 2の画像 2
    • 吸盤カップを引き上げて、ディスプレイを持ち上げてiPhoneを開けます。
    • 10度以上ディスプレイを持ち上げないでください。デバイスの右端にはリボンケーブルがあり、ディスプレイとロジックボードを繋いでいます。
  9. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 9、 1の画像 1
    • 吸盤カップの小さなノブを持ち上げてフロントパネルから外します。
  10. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 10、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 10、 2の画像 2
    • 開口ピックをiPhoneのリアケースとフロントパネルの間の上端に差し込みます。スクリーンを固定している残りの圧着剤を剥がします。
    • デバイス上端にあるプラスチック製クリップにダメージを与えないようご注意ください。
  11. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 11、 3の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 11、 3の画像 2 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 11、 3の画像 3
    • デバイスの上端からディスプレイアセンブリをわずかに引き離し、背面ケースに留められたクリップを外します。
    • 本のバックカバーを開くように、左側からディスプレイをめくってiPhoneの内部を開いていきます。
    • ディスプレイを完全に外さないでください。まだリボンケーブルがiPhoneのロジックボードに接続されています。
  12. iPhone7のWi-Fiダイバーシティアンテナの交換, バッテリー接続の外し方: 手順 12、 1の画像 1
    この手順で使用する道具:
    Tri-point Y000 Screwdriver
    $5.99
    購入する
    • 下部のコネクターブラケットから次の長さの トライポイント Y000 ネジを4本を取り外します。
    • 1.2 mmネジー3本
    • 2.4 mmネジー1本
    • 修理作業中は、各ネジを きちんと管理してください 。再組み立ての際は、iPhoneへのダメージを防ぐため、正しい位置に装着しましょう。
    Ahhh shoot! accidentally ordered tri-wing vs tri-point (must have just looked for y000).. It seems they only did this to annoy repair folks because not everything is tri-point on the phone...
    Steve - 返信
    These screws just spin for me. They don't back out, but the heads aren't stripped either. I've tried applying backpressure to help lift the screws, but no luck
    Jeff Hurst - 返信
    The Y000 took out one of the screws but not the other 3. I even tried the PH000 as suggested but nothing.
    dbright - 返信
    What driver do I need to remove these screws i’m stuck
    Nasser Nader - 返信
    i cant use, the Y000 it isnt working.
    joscarlos91 - 返信
    What if I stripped a screw what do I do??
    Jacob Ramos - 返信
    Yep, only the 2.4mm came out, other 3 won’t budge, and worried I’ve stripped the heads. Anyone got any ideas?
    Stephen Babbage - 返信
    It’s the screwdriver bit that is the problem. I had the same issue with 2 Y000 bits not grabbing the screw properly. I fixed it by using a small 3 sided file to slightly grind the groves in the Y000 bit just a bit deeper. Then the bit worked like a charm on these screws.
    Jim Staples - 返信
    Use Y000 on all 4. U have to be very sensitive on the 1.2mm screws. Put the bit in the screw, put the left pointing finger on top of the screwdriver and turn the driver carefully to the right until you feel a “bump”, thats the trick :-), then you are able to screw the screw out.
    Magne Eivindson - 返信
    For me the key here was a LOT of downward pressure to ensure the Y000 bit caught in the screw. Not sure i can describe how much exactly, but is was significant. Otherwise the bit would not catch.
    Erik Fredriksen - 返信
    What do I do if I Stripped one of them?
    Adam Corral - 返信
    Can’t get them removed what to do ?
    cowling_luke - 返信
    Managed to get the central one out. The upper one won't move, the lower one I've popped out with some force. This allows you to rotate the cover enough to unplug the various bits. Not ideal, but works. I've tried applying a lot of pressure, using the tighten/ loosen method, but the heads have just got mashed… no wonder Samsung are now No1, sigh…
    jimpoolio - 返信
    You need to be careful when just rotating the cover as you can accidentally slice through the two black antennas! You only need to nip them…As you can tell I have done this in the past :/
    Kyle Webb -
    The first, longer screw came out fine, but the other three wouldn’t budge, regardless of more/less pressure or a slight angle or anything. I finally filed down the tip of the Y000 bit ever so slightly, and then it worked. Hope this helps someone.
    Harmony - 返信
    Filing down the bit worked for me. The tip about putting an index finger on the end of the screwdriver handles and then turning gently until it clicks into place was very helpful! Using these 2 tips I didn't need much downward pressure. Screws are out in a few turns.
    Chris Bennett - 返信
    If you can’t get the bit to grip the screw properly, you can use a little bit of the water-proof sealing between the bit and the screw. That worked for me. Hope this helps anyone.
    jvalaamo - 返信
    Mine came out easily. I placed the screws in the area where the bit goes in my kit so I can keep track.
    Gina Torres - 返信
    I used a bunch of medicine cups to track my screws. You need like 12 if you want them all in cups. I ran out. There are so many different sizes that literally vary by 1mm. The tolerances on these things are tight.
    Ray Bieze - 返信
    I use a 28 day pill box and keep every screw separate and reburn to exact slot because they all vary in length, width and can really damage u phone if too long and nt secure if to small.  use a magnetised screwdriver,  or make the cheap freebees magnetic for a short period by rubbing it up an a magnet. lol
    scallyteacher - 返信
    Absolutely ridiculous had to go get a different one just stupid
    mark golling - 返信
    I couldn’t get the lowest one out and just turned the metal bracket out of the way and replaced battery.
    qwerty77x - 返信
    Was able to get the outer bracket screws out using fine needle nose pliers 90 degrees straight down for the outer ones by pressing down a little and using medium gripping force. Had to take these out first before i could use tweezers on the middle one, for which I had to use tweezers to hold the screw, then rotating the bracket (not the screw) counter clockwise a few mm many times over to slowly unscrew it 1/32th of a turn at a time, repeat. (this loosened middle screw). Think ‘rotating bracket 3minutes/degrees counterclockwise at a time while holding screw in place.) You are gonna need really small/fine pliers and tweezers for this because the heads are countersunk into the bracket.
    Galen Wollenberg - 返信
    The top screw in the step was much longer than 1.2mm. It has the same head as the 1.2mm, but different than the 2.4mm. It’s good to keep track of where they came from.
    All are so small that I thought I’d lost one, when it was still sitting in the phone.
    Mark - 返信
    To help tell if the screw is turning, put a small dot from a marker on the head of the screws.  This helped me to know I wasn't just stripping the head.
    Darren Thibodaux - 返信
    try heating the iPhone with a hairdryer or a bag of rice or about 60 degrees in an oven for 3 minutes . It has worked for me. If the screws don’t come out while hot the will come out as the iPhone cools.
    David Howard - 返信
    A small tapered triangle file using moderate pressure did the trick for me.
    Jack - 返信
  13. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 13、 1の画像 1
    • 下側のコネクターブラケットを取り出します。
    my battery cable connector was stuck to the bottom of this metal bracket plate so be careful when you lift it off
    Josh Martin - 返信
    This may have been intentionally done by Apple to make sure the battery gets disconnected before any other connector is disconnected. So always make sure to disconnect the battery before disconnecting and reconnecting the connectors for the display.
    Oscar Moreno - 返信
    So…I forgot to put this bracket back on when reassembling. Now I’ve adhered the display to the case and don’t have another adhesive strip…so I’m wondering: what purpose does this bracket serve? The phone is powering on and seems to work okay.
    Am I going to run into trouble with this bracket missing?
    Ian Fritz - 返信
    Well, that didn’t last long. The phone shuts down without warning. So I guess that plate is important…
    Ian Fritz -
    I also forgot to put the battery shield in, and adhered the display. I’m tempted to leave it like that. However, your negative experience is a good data point telling me to not be cheap.
    Ordered a new adhesive , under $2 shipped from eBay.
    Yishai Sered -
    Thanks, Josh Martin! Mine was stuck too, so I lifted carefully.
    Cynthia Lamb - 返信
  14. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 14、 3の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 14、 3の画像 2 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 14、 3の画像 3
    • スパッジャーの尖ったほうの先端を使って、バッテリーコネクターをロジックボードのソケットから外します。
    • バッテリーコネクターがソケットに接触してiPhoneの電源が入らないようにするため、わずかにコネクターケーブルを上に曲げます。
    Was kann passieren wenn man diesses Kabel vergessen hat zu entfernen `?
    Julian Eltrich - 返信
    Reconnecting the battery poorly can cause the iPhone to appear to be properly powered and functional, but then suffer a reboot loop.
    I had difficulty after a screen replacement, and the Console app on my Mac showed that the ‘thermalmonitord’ process was throwing lots of errors from not getting any sensor readings from the battery. It would never charge past 1% and just kept rebooting.
    The contacts on this conector looked fine so even though I had reseated this connector several times already, I reconnected it very firmly using my thumb and a spudger to really press all the corners and middle and really gave it a good massage and then finally it showed the normal dead battery screen and started properly charging and eventually booted back up to normal functionality.
    It seems the battery has to be able to transmit data to the phone to say it’s not overheating or iOS will not allow any current into the battery to recharge it, and the kernel will panic from the null readings and just reboot over and over again.
    jason - 返信
    In my case, the battery connector was attached to the bracket. We just left it connected bracket when we pryed it up.
    Dave Miller - 返信
    Reconnecting the battery connector was a bit difficult in my case. The cable that comes out of the battery was a tiny bit too long, or that I placed the battery a bit too high (i.e., too close to the top of the phone). It took me several frustrating minutes of fiddling with the connector for it to sit right into the socket. I was not sure if that was connected correctly but, alas, the phone came back to life when it was turned back on.
    Tomoharu Eguchi - 返信
    VERY IMPORTANT NOTE: Please READ the reply here by jason.
    It is very easy to knock off or nudge the little pins near the battery socket, see https://guide-images.cdn.ifixit.com/igi/... and https://guide-images.cdn.ifixit.com/igi/....
    Those pins are the data lines to extract battery info: temperature, charge, etc. If you accidentally nudge/knock off them the phone could appear to work normally, even for a few days. But then you will start getting wrong battery reads and then after that it may suffer a reboot loop. If you enter settings > privacy > analytics & improvements and you scroll down you will find panic errors from thermalmonitord that there are missing sensors (TG0B or TGXXX) and you will have to micro solder them. DO NOT NUDGE THEM and double check the socket connector when reconnecting the battery.
    PJM - 返信
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all! Careful removing the lower bracket - mine was stuck to this battery connector, which came up with the bracket. Luckily no cable or connector damage. Be careful. Thank you all!
    dantegd - 返信
    after installing new ifixit battery kit, note the foam on the new battery is thicker than old apple one, managed to remove the old foam and swap to new battery connector, sheild plate now level
    Neil Mills - 返信
  15. iPhone7のWi-Fiダイバーシティアンテナの交換, ディスプレイアセンブリ: 手順 15、 3の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換, ディスプレイアセンブリ: 手順 15、 3の画像 2 iPhone7のWi-Fiダイバーシティアンテナの交換, ディスプレイアセンブリ: 手順 15、 3の画像 3
    • この手順でケーブルの接続を外したり再接続する前にバッテリーが切れていることを確認してください。
    • スパッジャーの平面側先端や指の爪を使って、ロジックボード上のソケットから2つのディスプレイコネクタをまっすぐ引き上げて、接続を外します。
    • これらのケーブルを再接続する際は、カチッと音がして装着されるまで、コネクタの先端をソケットに押し込みます。それから反対側のコネクタも同じ作業を繰り返します。コネクタの中央部分を押さないでください。コネクタが僅かでもずれてしまうと曲がってしまい、永続的なダメージの原因となります。
    • もしiPhoneを組み立て直した後に、画面が真っ暗になったり、白い線が表示されたり、タッチの反応が悪い場合は、両方のケーブルを取り外して慎重に再接続し、完全に装着されていることを確認してください。
    To be honest you don’t really need to disconnect the display cables in step 15 or 16 to get the battery out. Just keep the suction cup on the screen to keep it propped up and to give the cables some slack. The only reason to take these cables off is that it’s a pain to apply the replacement display adhesive with those cables in the way. If you’re not re-waterproofing your phone just leave these attached.
    iPhoneディスプレイ用接着剤の交換
    minimalist - 返信
    MAKE SURE you hold the top screen when dislodging the cable connections. I let the screen lie flat down and ended up tearing one of the cable connections, now my touch ID does not work at all! I’m going to have to order a whole new screen.
    Arjun Nagarajan - 返信
    Don’t miss that SECOND CONNECTOR like I did. It will break very easily if not disconnected :(
    garrett peek - 返信
    An earlier comment said to re-apply the suction cup to the right side of the display so that it acts as a stand when the phone is partially opened. That’s a great idea, and helps a lot for this step and the next.
    Mark - 返信
    Hey – I broke one of these flex cables and I cant find them to purchase anywhere. Can somebody help me? It’s the LCD connector first and what is the second flex cable for? Thanks!
    Chan Ty - 返信
    I broke the second (smaller) display connector flex cable.
    1) Is it replaceable or repairable?
    2) Where can I get the replacement?
    Ben Blom - 返信
    Same happened to me. What solution did you find? Could you replace a part to make it work? Thank you!
    Viktoria -
    I replaced the screen and have ended up with a blank screen. Touch control seem to work (touch button works and I can shut down the phone by pressing power button for some seconds and then swipe left to right in the upper part of the screen). But the screen is blank. I’ve tried to disconnect and connect the two connectors in step 16 but with the same result (blank screen). What do I need to do?
    Thanks for advice!
    Bjorn - 返信
    this point is the most important in the whole manual.
    Please pay attention not to strain the flex cables or they will end up breaking
    Jose Joaquín Sanz Iniesta - 返信
    I should have been more careful - the second cable tore off.
    My own fault after having done this replacement about four times previously without any issues, I clearly got cocky and didn’t pay enough attention.
    Be VERY CAREFUL and remember to unplug those cables. Don’t skip steps.
    I’ve now had to order a replacement screen.
    Stuart - 返信
    Echo minimalist’s comment here. Prop the display up and skip to step 19 to save time and remove risk.
    .A. - 返信
    If you replace the screen and there is no display apply io propyl alcohol 99.9 & purse to both connectors on the screen and on the iPhone with a clean toothbrush and let them dry for 45 minutes and then fit the screen and reassemble the iPhone..
    It works for me . when I get a new screen I do t5his before fitting it.
    David Howard - 返信
    I tried to save time by not removing the screen during battery replacement as some comment here, HOWEVER, I ended up having to use a little force to remove the battery and in the process broke the second, lower smaller cable, resulting in loss of home button function and needing to get a new screen. Next time I will follow these steps and completely remove the screen during a battery replacement
    chrislacey - 返信
    I removed the screen and cable still got ripped during reassembling :(
    Viktoria -
    There is a critical fact missing from the steps here, for reassembly: That bottom (underlying) cable is longer than it should be. Loads of people are reporting that the Home button is dead after this repair, but the cables aren't torn. I'm pretty sure this is why. Here is a picture of the problem.
    When reassembling the phone, you must poke this cable back into the body of the phone while you bring the halves together, or you will crush, crimp, and destroy the cable.
    Gavin Stokes - 返信
    I’m only reading your very useful comment now, after the exact thing happened to me and my cable got ripped during reassembling phone. Would you be able helping me naming this part, so I can look for a new one? Thank you very much!
    Viktoria -
    thanks gavin. ifixit should have included this piece of info.
    soupamanx -
    Can somebody help me with the name of the part that these cables belong to? The bottom one got ripped during my battery replacement, I need a new one but unsure what to look for.
    Viktoria - 返信
  16. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 16、 3の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 16、 3の画像 2 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 16、 3の画像 3
    • 正面パネルのセンサーアセンブリコネクター上に固定されたブラケットから1.3 mm #000プラスネジを2本外します。
    • あるデバイスによってはY000が使用されています。Appleは製品の製造ラインの途中からY000ネジの使用に切り替えました。
    Has anyone had trouble getting these two screws off? I’ve been working on these for about 10 minutes and the LEFT screw wont spin. It seems like the little PH000 screwdriver bit won’t even grip it. (The one of the right comes off, no problem)
    It looks like I’ll have to pick this project up again with a screwdriver that will actually take off this piece.
    Makana Sylva - 返信
    If you’re having trouble removing these screws;
    the screw on the right goes into a standoff screw that is screwed into the frame.The left one goes into the logicboard.
    If your phone is used most likely it has been repaired in the past and the person that repaired it put the screws in way too tight.
    If your phone is brand new And you know 100% it is then the problem is your screwdriver.Stop before you strip it completely and buy a better screwdriver (EBAY).
    If you already stripped the screw head take the phone to a shop before you break it.
    there are ways to get them out but truthfully it’s extremely dangerous and sometimes your better off quitting while you are ahead.
    Vegeta Barrett -
    The right screw kept spinning, tried different levels of force but didn’t work. I left the screw on and bent the shield to get to the cable.
    s h - 返信
    I used a #1 flat head tip to loosen.
    Peter Pearson - 返信
    I couldn’t get the two screws out either—used the correct screw tip and everything. Stripped the screw. Will now attempt to just keep the cable attached…..
    Therese Peffer - 返信
    Use the PH000 and apply a little more force before spinning, should come right out!
    Sierra Scolaro - 返信
    ^To anyone having trouble, this is the correct answer. Put the phone on a firm surface, align your driver carefully, press down hard, and twist. As long as your driver is approximately the right size, it’ll come out.
    Jeff Suovanen -
    the two screw i have are stripped and i have n way of getting either screws off whats my next bet
    Alexis Marie Colon - 返信
    The PH000 bit is to large. I can’t get the screws out either which really sucks…now I have to put everything back together, find another bit that will work and try this again another day. Not impressed with IFIXIT’s attention to detail so far :-(
    Ryan Welborn - 返信
    Using iFixit’s driver kit, I prefer a PH00 for this, which is larger than the PH000. If you think the PH000 is too big, something is wrong.
    Jeff Suovanen -
    I think part of the issue with the iFixit PH000 is that it is slightly too pointy. The PH00 fits better because the splines engage the slots of the screw before the point bottoms out. The PH000 tip bottoms out in the screw’s center point and the splines don’t engage as well. I have other PH000 tips that are more blunt nose and they work better than the iFixit bit.
    rcarswell - 返信
    Use the J00 bit. Worked perfectly
    efazio588 - 返信
    PH000 screwdriver didn’t work for any of these screws, or the barometric vent, or the taptic engine. It was too big. I had to use a different screwdriver from another kit I had.
    minimalist - 返信
    I’d do this step before removing the ribbon cables by the battery connector. That way you can disconnect all of them at the same time.
    Ray Bieze - 返信
    i used the little +-shape 30 mm screwdriver (not the Y…but the + shape).
    mason - 返信
    the cable tore. is that it i need a new phone?
    patricia loving - 返信
    You don’t need a new phone, but your selfie camera and phone speaker will not work. You can get replacements for that about $10.
    jack jones - 返信
    Reconnecting this cable and coverplate took a good 20 minutes. O_O
    Nicole Crome - 返信
    What can I do to remove the screw (I stripped it)
    Alex Vu - 返信
    I also had issues to loosen up the screws, in two parts the right side up and the left side down, i think the PH000 is to pointy or something or its too hard for the srews of the iphone, i cannot take it off and know im regreting i bought i order all the way from Paraguay in south america and know so angry it doesnt work
    I skipped this step. Just be really careful not to pull on the screen.
    Takumi Arai - 返信
    The guide says they changed these to the Y000 “at some point in the t middle of the product’s lifecycle”…
    That can’t be true, I have a *day one*, preordered iPhone 7, and mine had, unmistakably, Y000 screws!
    and also, I’m just faithfully following the guide here, but can anyone clarify *why* is is necessary to entirely remove the display AND the Taptic Engine at all? The battery seems accessible just fine… oh well
    PS- I’m doing this on an older backup iPhone 7. My iPhone 12 Pro just went berserk and stopped working completely a little over a year after I got it day one of its release… since the iPhone X I’ve only had easily breakable, overly sensitive phones. I’ve had every numbered iPhone except for the 8 (I got the X released at the same date) and the 11, and man, are these newer iPhones post X fragile!
    Cam F - 返信
    This worked for me! As mentioned use PH000 and apply pressure and then unscrew the screws. They are tiny, adhere to a piece of tape so you don't lose them.
    Rosie J - 返信
  17. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 17、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 17、 2の画像 2
    • 正面パネルのセンサーアセンブリコネクターの接続をロジックボード上のソケットから外します。
    • 再度接続する際には、この平たいコネクターが曲がるリスクを最小にするために、コネクターを一度に接続してください。
    Das ist sehr mutig, das Kabel dort so zu strapazieren.
    Mich würde das Display daneben stellen und mit irgendetwas stützen, dass es nicht umkippen kann um Beschädigungen an dem Kabel zu vermeiden. Das reißt sehr schnell ein.
    Detlef Menninger - 返信
    Is this the connector for the earpiece, as well? I did the screen replacement and everything worked, except now I can’t use my earpiece… I’m afraid I didn’t fully connect this particular portion.
    Victor Bui - 返信
    @victorbui714 Correct, this is also the connector for the earpiece speaker. Check the flex cable carefully and make sure it wasn’t pinched or torn. Make sure the connector socket is clean (give it a blast with some compressed air if needed) and try reseating it. If that doesn’t help, you may want to remove the earpiece speaker and inspect the four springs on the back, and check that they’re intact and making good contact with the four circular pads on the flex cable. Give the pads a wipe with some IPA and try not to leave any skin oils on them. If none of that works, try replacing the entire flex cable/sensor assembly. Good luck!
    Jeff Suovanen -
    This is the only connector that is quite easily possible to put back in the wrong way. If you do so, the phone will just get into a continuous loop where it shows the boot screen, goes blank and then shows the boot screen again and again. If this happens, do not despair-just put it back in the right way.
    Roy Mathew - 返信
    After putting together, I had a continuous loop boot up (as noted above). I saw articles where this (front panel sensor connection) was the reason. I disconnected this connection and the boot up loop stopped. I tried reconnecting several times but had the same problem (boot up loop). However, it turns out that I needed to apply extra pressure when installing until a heard a (faint) second click when pressing down. Note - before I was using the spudger to press the connection together, which didn’t do the job. I ended up using my finger to press harder to get it to click in. Solved that issue.
    Ed Scannell - 返信
    The ribbon cable on this step is torn. Is this something that can be replaced? Is this only to the earpiece?
    John Daily - 返信
    Sarah Valencia - 返信
  18. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 18、 1の画像 1
    When removing the screen, be aware of the two tiny square black rubber grommets on the Penelope screw brackets that secure the screen. They can fall off very easily and be lost without even knowing it (it happened to me, but was lucky enough to find them).
    Guy Cooley - 返信
    Sorry, I’m so unclear about when to replace the Adhesive tape. Should I put the iPhone 7 Display Assembly Adhesive at this step, or after I’ve replaced the battery?
    Victor Bui - 返信
    @victorbui714 Battery first, then adhesive during reassembly, as it says in the instructions. ;)
    Jeff Suovanen -
    This is the 3rd screen iv put in my phone and everyone them bust at the top by the camera every time iv bought one of these screen idk if it’s the manufactures fault or what?
    trent bost - 返信
    @trentb28922 Ouch! That’s not normal. Is your phone’s frame bent? Are you having to use a lot of force when you install the display?
    Jeff Suovanen -
    If the instructions are followed step by step, then adding the adhesive comes before changing the battery.
    If I had to do it all over again, I'd skip adding the adhesive, because you have to disconnect the battery, plus the two lower display connecters and the front panel sensor assembly connector. It was a nightmare trying to marry the components back together without disturbing the wire prongs, and I don't even want to talk about reinserting the tiny screws that kept twirling around on the tip of the screwdriver as well. It wasn't worth the time or aggravation!!
    If you decide to skip this step, just avoid using your iPhone near water.
    Rosie J - 返信
  19. iPhone7のWi-Fiダイバーシティアンテナの交換, 気圧ベント: 手順 19、 1の画像 1
    • 背面ケースに留められている気圧ベントの2本の1.9 mmプラスネジを取り外します。
    The barometric vent seems to have some foam cushioning towards the bottom of the case? does this get damaged via removal I wonder?
    Phil - 返信
    I’m stucked with the right screw, can't get it out. Any ideas?
    Racecar - 返信
    Edit: I’ve lifted the taptic engine without unplugging it. Removing the battery stripes didn't cause any issues.
    Racecar -
    I didn't see the necessity, so I didn't remove the Barometric Vent since I decided I wasn't going to uplug the Taptic Engine, although I did remove screws for the Taptic Engine, but I didn't unplug it. I believe the point of removing the Taptic Engine is to gain access and space to pull the adhesive strips off the battery. If you attempt and are able to remove the adhesive off the battery, then I believe it's NOT necessary to remove the Barometric Vent nor the Taptic Engine.
    Rosie J - 返信
  20. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 20、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 20、 2の画像 2
    • ベントを取り出します。
  21. iPhone7のWi-Fiダイバーシティアンテナの交換, Taptic Engine: 手順 21、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換, Taptic Engine: 手順 21、 2の画像 2
    • スパッジャーの平面側の先端を使って、Taptic Engineのコネクターをロジックボードのソケットから外してください。
    Rosie J - 返信
  22. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 22、 1の画像 1
    • Taptic Engineを背面ケースに留めている3本の1.6 mmプラスネジを外します。
    My screws are stripped here. Please help, I don’t know what to do!
    Salva Alcón - 返信
    My screws are also stripped here, but the phone has never been opened before!
    Kyle Webb - 返信
    Hey Salva and Kyle, sorry to hear about all these stripped screws! For help with removing them, check out our guide.
    Adam O'Camb - 返信
    I had a new phone. These screws were missing when I disassembled it. Not sure what QC Apple has, but it ain’t great. If they’re missing it’s not the end of the world. You can just disable taptic touch.
    Ray Bieze - 返信
    I had my 7 battery replaced by an Apple Authorized dealer. Around 2 weeks after the taptic engine started to make a !&&* of a noise when it was activated (sounded as if it was loose)… then 1 month after that… it stopped working completely. fast forward 8-9 months later, the battery they had replaced just wasn’t holding its charge anymore (phone was spending more time plugged in charging and depleting very quickly = full charge lasted about 1-2 hours). Having bought the ifixit battery and have gotten as far as this step, I could see that all three of the 1.6mm screws were just floating around in the compartment and the taptic engine was just being held on via it’s ribbon lead. WTF?! Screws aren’t stripped and I managed to fix it in again. Why would these screws be floating around like this??
    Phil - 返信
    another person checking in here to assure you that, if you find a stripped screw (or more) at this step, you’re not crazy. I have one as well! I’m in dis-effing-belief. This phone has NEVER been serviced by anyone, and was allegedly brand new when purchased.
    To the person suggesting a dremel tool to remedy this…. *blink**Blink*. Are you kidding me right now? *slap*. Vibrating the !&&* out of all those sensitive parts - not to mention what one slip could end in your phone being effectively sawed in half.
    Cunning Stunt - 返信
  23. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 23、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 23、 2の画像 2
    • Taptic Engineを取り出します。
  24. iPhone7のWi-Fiダイバーシティアンテナの交換, スピーカーアセンブリ: 手順 24、 1の画像 1
    • WiFiダイバーシティアンテナを背面ケースに固定しているプラスネジを取り出します。
    • 3.2 mmネジー1本
  25. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 25、 1の画像 1
    • スピーカーを背面ケースに固定している次のプラスネジを3本外します。
    • 1.3 mmネジー2本
    • 2.0 mmネジー1本
  26. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 26、 3の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 26、 3の画像 2 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 26、 3の画像 3
    • スパッジャーの先端を使って、2本のアンテナケーブルをロジックボード上のソケットから接続を外します。
    Hey may i ask…what is the use of both of the antenna cables?i just opened my iphone 7 plus and i found both of the cables are broken.if both of the cables are broken,what does it effect on my iphone?
    Mohd Wazirul - 返信
    Speaker and antenna?
    Keah Smith - 返信
    I'm missing the black thing from my antenna and I have no signal, could this be the reason why? Is the black thing insulation?
    Keah Smith - 返信
    These doodads are a pain to route and reconnect. I probably spent 15 minutes just on this part of reassembly. One of them is connected to the new part. It won’t have the soft grommet on top.
    Ray Bieze - 返信
    One of these came away from its base. The one nearest the battery.
    When I reassemble it I’m thinking just a bit of glue at the side once re attached to base, so lomg as it touches the base contacts?
    Any comments?
    ANDREW - 返信
    I am having the worst time imaginable trying to reconnect the antenna cable coming from the lightening connector assembly to the logic board. It’s barely long enough and will not snap into place. There’s a minature gold pin sticking up from a circular gold ring on the logic board and I must have spent an hour on this one step. The antenna end has the female end. Everything else went well. The antenna connector from the old lightening assembly will connect relatively quickly. I’m beginning to think the new antenna connector female end might be defective. I’m ready to cut the black antenna wire and try to solder in a longer piece using the old connector assembly. Any ideas? HELP !!!
    David Sandrof - 返信
    These can be tricky to reconnect. I found the best way is to hold the connector with tweezers and use the point of a spudger on top of the connector in the other hand. Slowly moving the connector with the tweezers while applying gentle pressure with the spudger, you will eventually feel the connector and its seat line up and you can snap into place. Don’t force it, when it is lined up it is easy so you have to patiently work on aligning it.
    David Ege - 返信
    please say which antenna is which, impossible to know now
    Mitchell Thompson - 返信
    Tip that helped me: remove the standoff screw next to the clip before derouting (or, upon reassembly, rerouting) the cables. This gives you a lot more space to work with! (Note: I only did this on reassembly, so I don’t know if there are any gotchas on disassembly.)
    T Murrills - 返信
    Please pay close attention to witch one goes where or take a picture bad mistake made.
    michael - 返信
  27. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 27、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 27、 2の画像 2
    • ピンセットを使って、ロジックボード上のブラケットからアンテナケーブルを緩めます。(解放します)
  28. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 28、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 28、 2の画像 2
    • ピンセットを使って、スピーカー上のクリップからアンテナケーブルを取り出します。
    • ケーブルにダメージを与えないように、クリップ付近のケーブルを掴んでください。
    They pull off to the side.
    Ark - 返信
    This was an oddly challenging step, lifting the speaker slightly from the top end allowed me to slide the tips of one side of the tweezers in between the cable and the speaker, prying it out rather than grabbing and pulling which feels dangerous.
    Jesse de Vries -
    They break very easily
    Josh Brito - 返信
    difficile a retirer. Les 2 tables sont clipsés sur le haut parleur. Il m’a bien fallu 10 - 15 minutes pour arriver a les retirer. Aucune astuce a vous donner, a part de la persévérance.
    Guigui - 返信
    One cable seems to stay attached to the speaker. Don’t try to pry it off the speaker! This is shown in the video but not in these photos.
    Cynthia Lamb - 返信
  29. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 29、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 29、 2の画像 2
    • スパッジャーの先端を使って、ロジックボード側にスピーカーアセンブリをスライドさせ、背面ケースから取り出します。
  30. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 30、 1の画像 1
    • スピーカーを取り出します。
    Reassembly tip: after aligning the speaker with the bottom edge, instead of lowering the speaker into place, keep the speaker raised slightly and push the cables back into the clip (which were removed in step 28) with the flat end of a spudger. In doing so, though, make sure that the cable from the lightning connector piece remains above the flat metal piece protruding out the left side of the speaker.
    T Murrills - 返信
  31. iPhone7のWi-Fiダイバーシティアンテナの交換, Wi-Fiダイバーシティアンテナ: 手順 31、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換, Wi-Fiダイバーシティアンテナ: 手順 31、 2の画像 2
    • 丁寧にスピーカー上のクリップからアンテナを取り出します。
  32. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 32、 2の画像 1 iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 32、 2の画像 2
    • ピンセットを使って丁寧にタブを掴んでスピーカーから取り出します。
  33. iPhone7のWi-Fiダイバーシティアンテナの交換: 手順 33、 1の画像 1
    • Wi-Fiダイバーシティアンテナを取り出します。
    When installing the new antenna, it seemed at first that the grommet hole for the screw on the left side did. It line up with the holes on the speaker and case. The key is to gently use the flat end of the spudger to nudge the ribbon up against the speaker and down. Then it lines up well and the antenna cable routes easily through the clip channel.
    David Ege - 返信
終わりに
デバイスを再組み立てする際はこれらのインストラクションを逆の順番に従って作業を進めてください。
34 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Scott Havard
メンバー登録日: 06/27/16
49,654 ポイント
31のガイドは作成済み
5 件のコメント
Qual’è e dove si trova l’antenna dei dati cellulare? Non quello del Wi-Fi
Nicola Canato - 返信
questa guida risolve il problema del wifi grigio?
Nino Galletta - 返信
vyřešili jste problém?
Lukáš Netečný -
Is this a potential fix for an iPhone that won’t allow the wi-fi to be turned on? The phone has been fully restored to factory but still won’t allow the wi-fi to be turned on. It is crossed out in the Control Center, and won’t allow it to be toggled on in the Settings.
bluebee_technology - 返信
Hey i have same issue with wifi did you get any solutions?
Yash fixs -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 63
過去 30 日: 280
今までの合計 73,317
