はじめに
Use this guide to replace a bent or damaged rear case, or to swap out the rear case for cosmetic reasons. The rear case serves as the chassis for the entire phone, so replacing it involves removing all the iPhone's components.
You can also use this guide to replace the following parts:
- IFC Bracket
- Loudspeaker Mount
- Microphone Mount
- Front Panel Clips
必要な工具と部品
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
この手順で使用する道具:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
この手順で使用する道具:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
One 2.9 mm screw
One 2.3 mm screw
Remove the following Phillips screws:
Three 1.3 mm screws
One 1.6 mm screw
One 3.0 mm screw
Insert a SIM eject tool into the hole in the SIM tray.
Press to eject the SIM tray.
Use the flat end of a spudger to peel the Lightning connector flex cable off the speaker.
Use the point of a spudger to disconnect the Taptic Engine flex cable from the lower flex cable.
Prepare an iOpener and lay it across the bottom of the phone to soften the adhesive holding the Lightning connector flex cable in place.
Wait about a minute for the adhesive to soften before removing the iOpener and continuing.
Remove the following four Phillips screws:
Three 2.0 mm screws holding the power button bracket in place
One 1.3 mm Phillips screw over the flash and microphone bracket
Remove the following screws holding the cellular antenna in place:
One 2.7 mm Phillips screw
One 1.7 mm Phillips screw
この手順で使用する道具:Plastic Cards$2.99
Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
After about a minute, flip the phone over and use a plastic card to tear through any remaining adhesive.
38 の人々がこのガイドを完成させました。
6 件のコメント
Absolutely brilliant clear instructions
i like a challenge !
whomever wrote this instruction is a star
many thx
chris
Wow Evan! This is Ashwin from bellarmine. This was done really well and it came in handy, thanks for the contribution!
perfect step by step guide.
Took me 3 hours to swap the cover.
only think that missed is the application of the adhesive for the battery and the screen.
thanks mate!!
