メインコンテンツにスキップ
Yamaha YPG-225 Keys Replacement
Kevin Green
Kevin Green とその他 3 人の作成者
最終更新日: January 28, 2014
10 - 15 分
簡単
高画質の画像が必要
Learn to remove and replace a broken key for your keyboard with this guide. The process is fairly simple and mostly requires the removal of screws.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Yamaha YPG-225 Keys Replacement, Batteries: 手順 1、 1の画像 1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Yamaha YPG-225 Keys Replacement: 手順 2、 1の画像 1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Yamaha YPG-225 Keys Replacement: 手順 3、 1の画像 1
    • Locate the six batteries and remove them from the battery cavity.
  4. Yamaha YPG-225 Keys Replacement, Faceplate: 手順 4、 1の画像 1
    • Remove the six 10mm screws at the top of the backplate.
  5. Yamaha YPG-225 Keys Replacement: 手順 5、 1の画像 1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Yamaha YPG-225 Keys Replacement: 手順 6、 1の画像 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Yamaha YPG-225 Keys Replacement: 手順 7、 1の画像 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Yamaha YPG-225 Keys Replacement: 手順 8、 2の画像 1 Yamaha YPG-225 Keys Replacement: 手順 8、 2の画像 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
  9. Yamaha YPG-225 Keys Replacement, Keys: 手順 9、 1の画像 1
    • Remove the 32mm screws that hold keys down.
    • Depending on which block of keys you wish to remove, there may be four screws instead of three.
  10. Yamaha YPG-225 Keys Replacement: 手順 10、 1の画像 1
    • Remove the block of keys that holds the key you wish to install.
    • To do this, apply a small force away from the top of the keys and slightly toward the floor.
    • If done correctly, the block of keys will come to a slight downward angle.
  11. Yamaha YPG-225 Keys Replacement: 手順 11、 2の画像 1 Yamaha YPG-225 Keys Replacement: 手順 11、 2の画像 2
    • Press the tab on the back side of the block of keys out and detach the black keys.
  12. Yamaha YPG-225 Keys Replacement: 手順 12、 1の画像 1
    • Remove the individual white key(s) or the black key set(s) that require replacement.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kevin Green
メンバー登録日: 09/18/12
308 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-62, Propen Fall 2012 Cal Poly, Team 2-62, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S2G62
2 メンバー
6のガイドは作成済み
3 件のコメント
Excellent, Although I've got a different type of yamaha keyboard, still good inside info.
Diederick Fokker - 返信
Great article. Thank you so much.
Andreas Devig - 返信
The instructions were very good and easy to understand. Question on the same subject. How about keys that have popped up on the key bed.
Donald Bryant - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 28
今までの合計 21,328
