メインコンテンツにスキップ
Xbox Series X Base Replacement
Spencer Day
Spencer Day とその他 人の作成者
最終更新日: December 5, 2024
5分
中レベル
Use this guide to replace or remove the base (aka foot or circular pad) on an Xbox Series X.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Xbox Series X Base Replacement, Unlatch the base: 手順 1、 3の画像 1 Xbox Series X Base Replacement, Unlatch the base: 手順 1、 3の画像 2 Xbox Series X Base Replacement, Unlatch the base: 手順 1、 3の画像 3
    • Before you begin, completely power down and unplug all cables from your console.
    • A locking tab on the bottom of the shell (under the base) holds the base in place.
    • You can access the tab through the vent holes on the back of your Xbox, but you may need a flashlight. Alternatively, you can remove the back panel for easier access.
    • Stick a long, skinny flathead screwdriver through one of the vent holes on the back of your Xbox, near the locking tab.
    • Insert the screwdriver between the locking tab and the base. This might take a few tries—use a flashlight if you're having trouble.
    • Use the screwdriver to pry the tab inward (away from the base) into its open and unlocked position.
    • Keep the tab held open for the next step.
  2. Xbox Series X Base Replacement, Twist and remove the base: 手順 2、 3の画像 1 Xbox Series X Base Replacement, Twist and remove the base: 手順 2、 3の画像 2 Xbox Series X Base Replacement, Twist and remove the base: 手順 2、 3の画像 3
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the Hello from Seattle line will be parallel with the device's sides.
終わりに
Congratulations on your repair!
作成者
1人の作成者と共同作成されました。
Spencer Day
メンバー登録日: 09/14/22
95,762 ポイント
662のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,548のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 74
