メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox One Wireless Controller Model 1708 Button Replacement
必要な工具と部品
  1. Xbox One Wireless Controller Model 1708 Button Replacement, Cover Plate: 手順 1、 2の画像 1 Xbox One Wireless Controller Model 1708 Button Replacement, Cover Plate: 手順 1、 2の画像 2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
    FixBotに聞いてみる
    コメントを追加
  2. Xbox One Wireless Controller Model 1708 Button Replacement: 手順 2、 2の画像 1 Xbox One Wireless Controller Model 1708 Button Replacement: 手順 2、 2の画像 2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    FixBotに聞いてみる
    コメントを追加
  3. Xbox One Wireless Controller Model 1708 Button Replacement: 手順 3、 1の画像 1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    FixBotに聞いてみる
    コメントを追加
  4. Xbox One Wireless Controller Model 1708 Button Replacement: 手順 4、 2の画像 1 Xbox One Wireless Controller Model 1708 Button Replacement: 手順 4、 2の画像 2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
    FixBotに聞いてみる
    コメントを追加
  5. Xbox One Wireless Controller Model 1708 Button Replacement: 手順 5、 1の画像 1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. Xbox One Wireless Controller Model 1708 Button Replacement, Tape Shock Motors in place: 手順 6、 3の画像 1 Xbox One Wireless Controller Model 1708 Button Replacement, Tape Shock Motors in place: 手順 6、 3の画像 2 Xbox One Wireless Controller Model 1708 Button Replacement, Tape Shock Motors in place: 手順 6、 3の画像 3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
    FixBotに聞いてみる
    コメントを追加
  7. Xbox One Wireless Controller Model 1708 Button Replacement, Directional Pad: 手順 7、 1の画像 1
    • Turn the device over and remove the directional pad by gently pulling it away from the controller.
    FixBotに聞いてみる
    コメントを追加
  8. Xbox One Wireless Controller Model 1708 Button Replacement, Joystick Caps: 手順 8、 1の画像 1
    • Pull the joysticks off of the controller.
    FixBotに聞いてみる
    コメントを追加
  9. Xbox One Wireless Controller Model 1708 Button Replacement, Top Motherboard: 手順 9、 1の画像 1
    • If the rumble motors fall out of frame, the wires may disconnect from the motherboard . The wires will have to be soldered to reattach the motor.
    • Turn the device over and remove the two 7mm torx-6 screws in the bottom left and right corners.
    FixBotに聞いてみる
    コメントを追加
  10. Xbox One Wireless Controller Model 1708 Button Replacement, De-soldering required: 手順 10、 3の画像 1 Xbox One Wireless Controller Model 1708 Button Replacement, De-soldering required: 手順 10、 3の画像 2 Xbox One Wireless Controller Model 1708 Button Replacement, De-soldering required: 手順 10、 3の画像 3
    • Firmly grasp the top and bottom motherboards in opposite hands, then gently pull them apart.
    • The top motherboard is still connected to the bottom motherboard. To fully separate the top motherboard, you will need to use a soldering iron.
    • Warning: Do not attempt to disconnect the shielded (gold colored) connector as it is extremely fragile you will break it. It runs between the two boards.
    • De-solder the shielded cable from the lower board instead of attempting to disconnect the connector. De-solder using micro soldering techniquest.
    FixBotに聞いてみる
    コメントを追加
  11. Xbox One Wireless Controller Model 1708 Button Replacement, 3.5 mm Audio Port: 手順 11、 2の画像 1 Xbox One Wireless Controller Model 1708 Button Replacement, 3.5 mm Audio Port: 手順 11、 2の画像 2
    • Remove the audio port from the bottom mother board.
    FixBotに聞いてみる
    コメントを追加
  12. Xbox One Wireless Controller Model 1708 Button Replacement, Bottom Motherboard: 手順 12、 3の画像 1 Xbox One Wireless Controller Model 1708 Button Replacement, Bottom Motherboard: 手順 12、 3の画像 2 Xbox One Wireless Controller Model 1708 Button Replacement, Bottom Motherboard: 手順 12、 3の画像 3
    • Remove the three 70mm torx-6 screws from the center of the bottom motherboard.
    • Remove the two 70mm torx-6 screws next to the rumble motors on the bottom motherboard.
    • Remove the one 70mm torx-6 screw located on the left side of the bottom motherboard.
    FixBotに聞いてみる
    コメントを追加
  13. Xbox One Wireless Controller Model 1708 Button Replacement: 手順 13、 1の画像 1
    • Use a plastic spudger to lift the plastic clip off the front pegs.
    • Remove the plastic clip by sliding it upwards.
    FixBotに聞いてみる
    コメントを追加
  14. Xbox One Wireless Controller Model 1708 Button Replacement: 手順 14、 2の画像 1 Xbox One Wireless Controller Model 1708 Button Replacement: 手順 14、 2の画像 2
    • Use a spudger to release the small hooks at each end of the left and right bumper.
    • After you release these hooks, be careful as you separate the face plate from the back of the controller. The connect/sync button (see second image) is held in by this face plate and will come loose as you perform this step.
    FixBotに聞いてみる
    コメントを追加
  15. Xbox One Wireless Controller Model 1708 Button Replacement: 手順 15、 1の画像 1
    • To avoid disconnecting the wires connected to the motherboard, lift the mother board away from the plastic frame as if opening a laptop.
    FixBotに聞いてみる
    コメントを追加
  16. Xbox One Wireless Controller Model 1708 Button Replacement, Front Buttons: 手順 16、 2の画像 1 Xbox One Wireless Controller Model 1708 Button Replacement, Front Buttons: 手順 16、 2の画像 2
    • Lift off the rubber backing strip.
    • With the rubber backing strip removed, the buttons will now fall out of the remaining shell.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
61 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Dylan Gross
メンバー登録日: 09/25/17
5,011 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017人のメンバー
CPSU-FORTE-F17S18G3
4 メンバー
42のガイドは作成済み
9件のガイドコメント
Thanks for the contribution for you and helped a lot of people.
NELSON ESTREMERA - 返信 共有
You don't need to desolder anything to remove the top motherboard!
Those black and grey wires go to the vibration motors in the triggers. Remove the covers on the triggers along with the motors, and carefully remove the wires from clips on the front of the controller. Make sure you get the black signal wire. You can now safely remove the two boards from eachother.
randomguy6527 - 返信 共有
I needed a guide for this because my “X” button was sticking and I ended up doing the whole thing without separating the motherboards, cleaning everything that touches the button, and it worked like a charm. Thank you very much for the guide!
Michael Winay - 返信 共有
Can you just take off the buttons right after removing the front faceplate?
Zanyar - 返信 共有
I wore out both the sticks playing COD, this helped me to make it usable enough for P2. cheers!
Nicholas Pratt III - 返信 共有
コメントを追加
統計データ:
過去 24時間: 22
過去 7 日: 113
過去 30 日: 493
今までの合計 54,908
