UE BOOM 2 Micro-USB Port Replacement
はじめに
手順 1 に進むThe micro-USB port is located under a rubber cover on the bottom of the UE Boom 2 speaker. Replacing this part requires the removal of the D-ring and rubber port cover, In addition the bottom pad must be removed, which will void the device warranty.
必要な工具と部品
First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
Remove by twisting in a counter-clockwise motion.
8 の人々がこのガイドを完成させました。
6 件のコメント
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
i too am looking to find the replacement part
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
Anyone have the part number to convert it to a USB type c instead of A?
