メインコンテンツにスキップ
Trek Neko Bike Brake Pad Replacement
Camille Nikaido
Camille Nikaido とその他 3 人の作成者
最終更新日: May 11, 2023
15 - 30 分
中レベル
Use this guide to replace a worn or damaged brake pad on your Trek Neko Bike.
Bike brakes allow you to stop your bike quickly and safely. Brake pads wear down over time or can break from damage. If you notice reduced stopping power, squeaking or grinding noises, or visible damage to your brake pad, it may be a sign that you need to replace it. Brake pads have a wear indicator line that shows when they need to be replaced. If your brake pad is worn down to the line, it's time to replace it.
It is important to replace your bike brake pad as soon as you notice any of these signs. Continuing to use worn out brake pads can be dangerous because it will be more difficult to stop quickly and safely.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Trek Neko Bike Brake Pad Replacement, Bike Brake Pad: 手順 1、 2の画像 1 Trek Neko Bike Brake Pad Replacement, Bike Brake Pad: 手順 1、 2の画像 2
    • Squeeze the two brake arms together.
    • Angle the brake noodle down.
    • Push the quick release down to release the brake noodle.
  2. Trek Neko Bike Brake Pad Replacement: 手順 2、 1の画像 1
    • Flip the bike over so that the seat is on the ground.
  3. Trek Neko Bike Brake Pad Replacement: 手順 3、 3の画像 1 Trek Neko Bike Brake Pad Replacement: 手順 3、 3の画像 2 Trek Neko Bike Brake Pad Replacement: 手順 3、 3の画像 3
    • Open the quick release lever on the bike wheel.
    • Rotate the lever in a counter clockwise direction to loosen the wheel.
    • Remove the wheel from the bike frame.
  4. Trek Neko Bike Brake Pad Replacement: 手順 4、 2の画像 1 Trek Neko Bike Brake Pad Replacement: 手順 4、 2の画像 2
    • Loosen the locking bolt on the brake pad with a 5 mm Allen wrench.
    • Remove the locking bolt, washers, and brake pad from the brake pad housing.
  5. Trek Neko Bike Brake Pad Replacement: 手順 5、 2の画像 1 Trek Neko Bike Brake Pad Replacement: 手順 5、 2の画像 2
    • Insert the new brake pad.
    • Insert the washers.
    • Insert the locking bolt.
  6. Trek Neko Bike Brake Pad Replacement: 手順 6、 2の画像 1 Trek Neko Bike Brake Pad Replacement: 手順 6、 2の画像 2
    • Tighten the brake pad locking bolt bolt clockwise until it is finger tight.
    • Tighten the bolt with a 5 mm Allen wrench.
  7. Trek Neko Bike Brake Pad Replacement: 手順 7、 3の画像 1 Trek Neko Bike Brake Pad Replacement: 手順 7、 3の画像 2 Trek Neko Bike Brake Pad Replacement: 手順 7、 3の画像 3
    • Reinsert the wheel.
    • Tighten the bolt on the wheel until it is finger tight.
    • Center the wheel in the frame.
    • Close the quick release lever to secure the wheel.
  8. Trek Neko Bike Brake Pad Replacement: 手順 8、 2の画像 1 Trek Neko Bike Brake Pad Replacement: 手順 8、 2の画像 2
    • Place the bike right side up.
  9. Trek Neko Bike Brake Pad Replacement: 手順 9、 3の画像 1 Trek Neko Bike Brake Pad Replacement: 手順 9、 3の画像 2 Trek Neko Bike Brake Pad Replacement: 手順 9、 3の画像 3
    • Insert the brake noodle into the quick release lever.
    • Angle the quick release lever upwards so that the brake noodle clicks into place.
  10. Trek Neko Bike Brake Pad Replacement: 手順 10、 2の画像 1 Trek Neko Bike Brake Pad Replacement: 手順 10、 2の画像 2
    • Squeeze the brakes to check proper fitment.
    • Tighten or loosen the quick release bolt on the brake arms to adjust based on preference.
終わりに
With properly installed brake pads, you can now safely ride your bike!
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Camille Nikaido
メンバー登録日: 02/02/23
181 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 1-9, Andersen Winter 2023 UC Davis, Team 1-9, Andersen Winter 2023人のメンバー
UCD-ANDERSEN-W23S1G9
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 40
今までの合計 428
