メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Trek FX2 Fitness Bike Saddle Replacement
David Fong
David Fong とその他 3 人の作成者
最終更新日: 2024年12月23日
10 - 15 分
簡単
This guide shows how to remove and replace a saddle on a bicycle. The steps include removing the current saddle, lubricating the bolts and rails, reinstalling the new saddle, and securing the saddle's connection to the frame.
The bike seat used in this guide is a Trek Fx2, a hybrid bike meant for fitness and commuting, although the instructions apply to many other bike saddles, whether they have two bolt or one bolt configurations. If you are unfamiliar with this process, we recommend taking some pictures of the different angles of your seat placement before starting so that you know what configuration to set it back to.
This process can be helpful when your bike saddle is damaged or if the seat is improperly set on the bike. With such replacement, you can continue to use your bike for its intended purpose.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Trek FX2 Fitness Bike Saddle Replacement, Saddle: 手順 1、 3の画像 1 Trek FX2 Fitness Bike Saddle Replacement, Saddle: 手順 1、 3の画像 2 Trek FX2 Fitness Bike Saddle Replacement, Saddle: 手順 1、 3の画像 3
    • Locate the bolt under the saddle.
    • Use a 5mm Allen Wrench to loosen and remove the M8x30 mm bolt.
    • Remove the saddle from under the plate.
  2. Trek FX2 Fitness Bike Saddle Replacement: 手順 2、 2の画像 1 Trek FX2 Fitness Bike Saddle Replacement: 手順 2、 2の画像 2
    • Use a towel covered in isopropyl rubbing alcohol to clean any dirt from the bolts and plate.
  3. Trek FX2 Fitness Bike Saddle Replacement: 手順 3、 2の画像 1 Trek FX2 Fitness Bike Saddle Replacement: 手順 3、 2の画像 2
    • Apply Finish Line Premium Grease to the bolt.
    • Work the grease around the threads.
  4. Trek FX2 Fitness Bike Saddle Replacement: 手順 4、 3の画像 1 Trek FX2 Fitness Bike Saddle Replacement: 手順 4、 3の画像 2 Trek FX2 Fitness Bike Saddle Replacement: 手順 4、 3の画像 3
    • Clean the replacement bicycle saddle with a towel and isopropyl alcohol.
  5. Trek FX2 Fitness Bike Saddle Replacement: 手順 5、 2の画像 1 Trek FX2 Fitness Bike Saddle Replacement: 手順 5、 2の画像 2
    • Apply Finish Line Premium Grease to the rails of the bicycle saddle.
  6. Trek FX2 Fitness Bike Saddle Replacement: 手順 6、 3の画像 1 Trek FX2 Fitness Bike Saddle Replacement: 手順 6、 3の画像 2 Trek FX2 Fitness Bike Saddle Replacement: 手順 6、 3の画像 3
    • Align the seat rails with the channels in the saddle plate.
    • Slide the rails into the channels of the saddle plate.
    • Adjust the seat position to your preference.
  7. Trek FX2 Fitness Bike Saddle Replacement: 手順 7、 3の画像 1 Trek FX2 Fitness Bike Saddle Replacement: 手順 7、 3の画像 2 Trek FX2 Fitness Bike Saddle Replacement: 手順 7、 3の画像 3
    • Insert the bolts into the holes on the saddle plate.
    • Tighten the bolts by hand until they are snug.
    • Use an Allen wrench to evenly tighten the bolts.
  8. Trek FX2 Fitness Bike Saddle Replacement: 手順 8、 1の画像 1
    • Sit on the seat to check its angle and stability.
終わりに
Test out the bike seat, and adjust accordingly.
Gear Up For Future Repairs
Shop all
作成者
3人の作成者と共同で作成されました。
David Fong
メンバー登録日: 11/05/24
157 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 4-6, Vidal-Chiesa Fall 2024 UC Davis, Team 4-6, Vidal-Chiesa Fall 2024人のメンバー
UCD-VIDAL-CHIESA-F24S4G6
3 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 35
今までの合計 524
