Trek 4300 Bicycle Rear Wheel Replacement
はじめに
手順 1 に進むThe rear wheel is removed similarly to the front wheel, however it will require maneuvering around the chain and gear mechanism.
Stand behind your bike straddling the rear wheel and locate the brake calipers.
To lessen the tension on the brake wire, place one hand on each caliper and push them towards one another.
To reassemble your device, lay the top chain on the smallest gear of the rear cassette and then follow the steps in reverse order beginning with step 3.
ある他の人がこのガイドを完成しました。
