メインコンテンツにスキップ
Toshiba Satellite L305D-S5950 LCD Screen Replacement
William
William とその他 3 人の作成者
最終更新日: July 15, 2014
15 - 20 分
中レベル
高画質の画像が必要
In order to replace the LCD screen on your device the keyboard and motherboard cover need to be removed.
The keyboard needs to be removed due to the cable connecting it to the motherboard interfering with the removal of the top part of the motherboard case.
The top part of the motherboard case needs to be removed due to it being in the way of the removal of the front part of the LCD case.
必要な工具と部品
ツール
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 2、 2の画像 1 Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 2、 2の画像 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 3、 2の画像 1 Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 3、 2の画像 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 4、 1の画像 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Keyboard: 手順 5、 2の画像 1 Toshiba Satellite L305D-S5950 LCD Screen Replacement, Keyboard: 手順 5、 2の画像 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 6、 1の画像 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 7、 3の画像 1 Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 7、 3の画像 2 Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 7、 3の画像 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 8、 1の画像 1
    • Remove the keyboard completely from the laptop.
  9. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Motherboard Cover: 手順 9、 2の画像 1 Toshiba Satellite L305D-S5950 LCD Screen Replacement, Motherboard Cover: 手順 9、 2の画像 2
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  10. Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 10、 3の画像 1 Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 10、 3の画像 2 Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 10、 3の画像 3
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  11. Toshiba Satellite L305D-S5950 LCD Screen Replacement, LCD Screen: 手順 11、 3の画像 1 Toshiba Satellite L305D-S5950 LCD Screen Replacement, LCD Screen: 手順 11、 3の画像 2 Toshiba Satellite L305D-S5950 LCD Screen Replacement, LCD Screen: 手順 11、 3の画像 3
    • Located and unscrew the four 5.25mm screws located on the four corners of the LCD screen.
    • There might be teflon pads covering them that need to be removed to see the screws.
    • Use your hands to pry off the frame around the LCD screen.
    • Remove the frame from the LCD screen.
  12. Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 12、 2の画像 1 Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 12、 2の画像 2
    • Remove the four 5.25mm screws on the sides of the LCD screen (this step will be done two times, for either side of the screen).
    • Remove the 5.25mm screw shown in the second picture.
    • Laptop has been rotated 180 degrees to complete the last step.
  13. Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 13、 3の画像 1 Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 13、 3の画像 2 Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 13、 3の画像 3
    • Unplug the wire located on the right side of the chip under the LCD screen
    • Unplug the wire located on the left side of the chip under the LCD screen. (Laptop has been rotated 180 degrees to complete this step)
    • Unplug the LCD screen from the motherboard.
  14. Toshiba Satellite L305D-S5950 LCD Screen Replacement: 手順 14、 1の画像 1
    • Remove the LCD screen from the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
William
メンバー登録日: 03/26/14
889 ポイント
7のガイドは作成済み
チーム
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S1G2
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 880
