メインコンテンツにスキップ
Toshiba Satellite L15W-B1208X Battery Replacement
Brian Herbster
Brian Herbster とその他 2 人の作成者
最終更新日: January 10, 2023
10 - 20 分
中レベル
This guide demonstrates how to remove a Toshiba Satellite L15W-B1208X battery. Reasons the battery might need replacing include not holding a charge, not charging, corrosion, damage, or swelling of the battery itself. If the battery has corrosion, is damaged, or has swollen then wear rubber gloves so that the battery fluids do not leak onto your hands. After the battery is removed, take it to the nearest recycling center that accepts lithium ion batteries for proper disposal.
必要な工具と部品
ツール
もっと見る
  1. Toshiba Satellite L15W-B1208X Battery Replacement, Battery: 手順 1、 2の画像 1 Toshiba Satellite L15W-B1208X Battery Replacement, Battery: 手順 1、 2の画像 2
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Battery Replacement: 手順 2、 3の画像 1 Toshiba Satellite L15W-B1208X Battery Replacement: 手順 2、 3の画像 2 Toshiba Satellite L15W-B1208X Battery Replacement: 手順 2、 3の画像 3
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Battery Replacement: 手順 3、 3の画像 1 Toshiba Satellite L15W-B1208X Battery Replacement: 手順 3、 3の画像 2 Toshiba Satellite L15W-B1208X Battery Replacement: 手順 3、 3の画像 3
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Battery Replacement: 手順 4、 3の画像 1 Toshiba Satellite L15W-B1208X Battery Replacement: 手順 4、 3の画像 2 Toshiba Satellite L15W-B1208X Battery Replacement: 手順 4、 3の画像 3
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Brian Herbster
メンバー登録日: 01/26/20
374 ポイント
3のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 635
