Toshiba Satellite C655D-S5084 Cooling Fan Replacement
はじめに
手順 1 に進むIs your computer getting too hot to handle? Overheating is a sign that your cooling fan may not be working properly, which may cause further damage to your computer. This guide will help you through the replacement of the cooling fan in your Toshiba Satellite C655D-S5084.
必要な工具と部品
Turn the device bottom-side up. Make sure the batter compartment is nearest you.
Unlock the right side of the battery.
Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
Remove the plastic cover.
Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
Remove the 5.5 mm (F5) screw with the Phillips #1 screwdriver.
9 の人々がこのガイドを完成させました。
2 件のコメント
Excellent description and very precise. I also upgraded to dual Wifi/ Bluetooth (easy to obtain now, lol). Thanks again!
HDD does not actually need to be removed to replace the fan (Steps 3-6) and can stay where it is.
Steps 17-20 can be completed much easier by removing the keyboard first.
Remove the plastic trim across the top of the keyboard.
Remove the 4 screws the trim covers.
Lift the keyboard carefully from the top, there are only tabs holding the bottom of the keyboards which the keyboard slides out from.
This makes it easy to get to the 4 cables shown in steps 17-20 for removal and reinstallation.
I will edit the guide once I've sorted the photos later today.
