メインコンテンツにスキップ
Sony Xperia XA Ultra Vibrator Module replacement
Walter Lackey
Walter Lackey とその他 3 人の作成者
最終更新日: May 7, 2024
40分
中レベル
This guide will show you how to replace the vibrating module of the Sony Xperia XA Ultra, in the event that the device's vibrating capabilities are weakened or stop working completely. To complete this guide, you will need a t3 and t5 torx screw driver, as well as a plastic spudge or wedging tool of some kind.
必要な工具と部品
ツール
もっと見る
  1. Sony Xperia XA Ultra Vibrator Module replacement, Motherboard: 手順 1、 2の画像 1 Sony Xperia XA Ultra Vibrator Module replacement, Motherboard: 手順 1、 2の画像 2
    • Carefully remove the back panel of the phone with a plastic spudger, or other flat and thin wedge tool. Work your way around the perimeter of the case, loosening and prying gently, until there is sufficient distance between the panel and phone.
  2. Sony Xperia XA Ultra Vibrator Module replacement: 手順 2、 2の画像 1 Sony Xperia XA Ultra Vibrator Module replacement: 手順 2、 2の画像 2
    • Remove all 9 black 4mm T5 screws.
    • Remove all 8 silver 3mm T3 screws.
    • Make sure to carefully place each screw in a secure location to avoid losing any.
  3. Sony Xperia XA Ultra Vibrator Module replacement: 手順 3、 3の画像 1 Sony Xperia XA Ultra Vibrator Module replacement: 手順 3、 3の画像 2 Sony Xperia XA Ultra Vibrator Module replacement: 手順 3、 3の画像 3
    • Near the top of the battery (area closest to camera) press the small latch in the highlighted area, push the latch away from the metal casing with the metal spudger.
    • Use the plastic opening tool to pry off the metal case. Be sure to carefully pry the casing slowly and at multiple angles and directions to insure nothing is damaged.
    • Be careful when prying near the top of the device. The metal casing can be easily bent.
  4. Sony Xperia XA Ultra Vibrator Module replacement: 手順 4、 2の画像 1 Sony Xperia XA Ultra Vibrator Module replacement: 手順 4、 2の画像 2
    • Remove the side bezels from each side, and remove the sim card cover.
  5. Sony Xperia XA Ultra Vibrator Module replacement: 手順 5、 2の画像 1 Sony Xperia XA Ultra Vibrator Module replacement: 手順 5、 2の画像 2
    • Using the plastic opening tool, gently pry off the black charge port plate, located near the bottom of the phone.
    • Remove the sim card from sim card slot using fingernail or small plastic spudger.
  6. Sony Xperia XA Ultra Vibrator Module replacement: 手順 6、 3の画像 1 Sony Xperia XA Ultra Vibrator Module replacement: 手順 6、 3の画像 2 Sony Xperia XA Ultra Vibrator Module replacement: 手順 6、 3の画像 3
    • Disconnect all four of the shown electrical connectors by gently prying up with the plastic opening tool.
  7. Sony Xperia XA Ultra Vibrator Module replacement: 手順 7、 2の画像 1 Sony Xperia XA Ultra Vibrator Module replacement: 手順 7、 2の画像 2
    • Working from bottom to top, gently pry the motherboard off of the phone .
    • The camera is connected to the motherboard. Be extremely careful when removing it to avoid damage.
  8. Sony Xperia XA Ultra Vibrator Module replacement, Vibrator module: 手順 8、 1の画像 1
    この手順で使用する道具:
    • Use tweezers to pull the vibrator module out of its socket.
    • Since the vibrator module is glued in place we recommend applying a low-level heat source to loosen the glue.
    • Be sure not to let the vibrator module become too hot to touch.
    • If using metal tweezers be careful not to touch any other phone components.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Walter Lackey
メンバー登録日: 09/22/17
419 ポイント
3のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 28
今までの合計 446
