メインコンテンツにスキップ
Sony Xperia XA Headphone Jack Replacement
Stephen Rock
Stephen Rock とその他 2 人の作成者
最終更新日: May 29, 2018
40分
中レベル
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device. The headphone jack is held in by plastic retaining clips and may pop off when removed.
必要な工具と部品
ツール
もっと見る
  1. Sony Xperia XA Headphone Jack Replacement, Back Cover: 手順 1、 1の画像 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Headphone Jack Replacement: 手順 2、 1の画像 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Headphone Jack Replacement: 手順 3、 3の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 3、 3の画像 2 Sony Xperia XA Headphone Jack Replacement: 手順 3、 3の画像 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Headphone Jack Replacement: 手順 4、 3の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 4、 3の画像 2 Sony Xperia XA Headphone Jack Replacement: 手順 4、 3の画像 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Headphone Jack Replacement: 手順 5、 1の画像 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Headphone Jack Replacement: 手順 6、 1の画像 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Headphone Jack Replacement, Motherboard: 手順 7、 2の画像 1 Sony Xperia XA Headphone Jack Replacement, Motherboard: 手順 7、 2の画像 2
    • Pry up the copper connector next to the battery with the plastic opening tool.
  8. Sony Xperia XA Headphone Jack Replacement: 手順 8、 2の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 8、 2の画像 2
    • Remove the five black 4mm screws with a Phillips #00 Screwdriver.
  9. Sony Xperia XA Headphone Jack Replacement: 手順 9、 3の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 9、 3の画像 2 Sony Xperia XA Headphone Jack Replacement: 手順 9、 3の画像 3
    • Pry up the black camera case with the plastic opening tool and then remove the case.
  10. Sony Xperia XA Headphone Jack Replacement: 手順 10、 2の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 10、 2の画像 2
    • Pop off the small connector on the right side of the motherboard with the plastic opening tool.
  11. Sony Xperia XA Headphone Jack Replacement: 手順 11、 2の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 11、 2の画像 2
    • Use the spudger to take off the connector in the top right of the motherboard.
  12. Sony Xperia XA Headphone Jack Replacement: 手順 12、 3の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 12、 3の画像 2 Sony Xperia XA Headphone Jack Replacement: 手順 12、 3の画像 3
    • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
    • Peel back the tab past the connector.
    • Tab is stuck with adhesive.
  13. Sony Xperia XA Headphone Jack Replacement: 手順 13、 3の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 13、 3の画像 2 Sony Xperia XA Headphone Jack Replacement: 手順 13、 3の画像 3
    • Pry up the camera's connector to the motherboard with the nylon spudger.
  14. Sony Xperia XA Headphone Jack Replacement: 手順 14、 2の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 14、 2の画像 2
    • Use the spudger to loosen the black connector from the top right of the motherboard.
  15. Sony Xperia XA Headphone Jack Replacement: 手順 15、 3の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 15、 3の画像 2 Sony Xperia XA Headphone Jack Replacement: 手順 15、 3の画像 3
    この手順で使用する道具:
    • Pull out the square shaped connector using tweezers.
  16. Sony Xperia XA Headphone Jack Replacement: 手順 16、 2の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 16、 2の画像 2
    • Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
  17. Sony Xperia XA Headphone Jack Replacement: 手順 17、 3の画像 1 Sony Xperia XA Headphone Jack Replacement: 手順 17、 3の画像 2 Sony Xperia XA Headphone Jack Replacement: 手順 17、 3の画像 3
    • Use the spudger to separate the motherboard from the frame.
    • Pull out the motherboard using your fingers.
  18. Sony Xperia XA Headphone Jack Replacement, Headphone Jack: 手順 18、 2の画像 1 Sony Xperia XA Headphone Jack Replacement, Headphone Jack: 手順 18、 2の画像 2
    • With the spudger, pry the headphone jack located in the top right corner of the phone.
    • The new headphone jack snaps into place in the right corner between the retaining clips.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Stephen Rock
メンバー登録日: 04/18/18
230 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G2, Livingston Spring 2018 Cal Poly, Team S17-G2, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S17G2
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 10
今までの合計 1,051
