メインコンテンツにスキップ
Sony Xperia XA Battery Replacement
Cassidy Davis
Cassidy Davis とその他 2 人の作成者
最終更新日: May 29, 2018
15分
中レベル
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
必要な工具と部品
ツール
もっと見る
  1. Sony Xperia XA Battery Replacement, Back Cover: 手順 1、 1の画像 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Battery Replacement: 手順 2、 1の画像 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Battery Replacement: 手順 3、 3の画像 1 Sony Xperia XA Battery Replacement: 手順 3、 3の画像 2 Sony Xperia XA Battery Replacement: 手順 3、 3の画像 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Battery Replacement: 手順 4、 3の画像 1 Sony Xperia XA Battery Replacement: 手順 4、 3の画像 2 Sony Xperia XA Battery Replacement: 手順 4、 3の画像 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Battery Replacement: 手順 5、 1の画像 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Battery Replacement: 手順 6、 1の画像 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Battery Replacement, Battery: 手順 7、 3の画像 1 Sony Xperia XA Battery Replacement, Battery: 手順 7、 3の画像 2 Sony Xperia XA Battery Replacement, Battery: 手順 7、 3の画像 3
    • Peel back the black tabs on the battery.
    • This may require some force as you are breaking the adhesive seal.
    • You will need to apply more adhesive for the reassembly.
  8. Sony Xperia XA Battery Replacement: 手順 8、 2の画像 1 Sony Xperia XA Battery Replacement: 手順 8、 2の画像 2
    • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
  9. Sony Xperia XA Battery Replacement: 手順 9、 1の画像 1
    • Use a plastic opening tool to get under the battery and pry it up.
  10. Sony Xperia XA Battery Replacement: 手順 10、 1の画像 1
    • Lift the battery out with your hands.
終わりに
11 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cassidy Davis
メンバー登録日: 04/18/18
621 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S17-G2, Livingston Spring 2018 Cal Poly, Team S17-G2, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S17G2
4 メンバー
8のガイドは作成済み
コメント 1 件
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
Mike Jurkiewicz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 15
今までの合計 5,433
