メインコンテンツにスキップ
Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement
Michael Smith
Michael Smith とその他 3 人の作成者
最終更新日: September 20, 2024
3分
簡単
In this guide we well be removing the internal HDD of the DCR-SR68 Handycam and replacing it with a new one. This will involve removing some of the exterior casing to access the HDD.
必要な工具と部品
  1. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): 手順 1、 1の画像 1
    • Undo Hand Strap
    • Remove battery.
    • Get the iFixit screwdriver and remove the extension.
    • Use a JO Philips head bit.
  2. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 2、 2の画像 1 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 2、 2の画像 2
    • Place device on left side with lens facing right.
    • Using the screwdriver, unscrew the left middle 3mm Philips screw.
    • Open the "DC IN" tabe. (Second 3mm Philips screw is revealed)
    • Unscrew this screw.
  3. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 3、 1の画像 1
    • Turn device over onto it's top with the lens facing right.
    • Unscrew the top left and top right 3mm Philips screws.
    • The right side casing is now free.
  4. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 4、 2の画像 1 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 4、 2の画像 2
    • Remove the right side casing by pulling up and away.
    • The HDD is now revealed.
  5. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 5、 3の画像 1 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 5、 3の画像 2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 5、 3の画像 3
    • Using your fingers, lift the HDD from it's right end, pivoting on it's left end.
    • The HDD ribbon wire is now exposed.
  6. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 6、 2の画像 1 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 6、 2の画像 2
    • Using your fingers, gently pull the ribbon wire out of it's socket.
    • The HDD is now free from the device.
  7. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 7、 2の画像 1 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 手順 7、 2の画像 2
    • Using your fingers, pull the black rubber bumpers off of the HDD.
    • Set the old HDD aside.
終わりに
18 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Michael Smith
メンバー登録日: 01/06/16
197 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 2-5, Andersen Winter 2016 Eastern Washington University, Team 2-5, Andersen Winter 2016人のメンバー
EWU-ANDERSEN-W16S2G5
5 メンバー
13のガイドは作成済み
9 件のコメント
Hi. Would you know if the hard drive of the sr67 would work in a sr 68? My sony handycam dcr sr67 Got water damage and I need to download videos. Can't find an old 67. 0nly 68. No one can fix the old one. Thanks renee
Renee - 返信
What does the letter H after hte HDD1818 stands for?
guimoramirez - 返信
My dcr-sr68 hdd not formting please find salution
Naman Jain - 返信
My SONY HANDYCAM DCR - SR68 HDD FORMATING shows Error E:31.00
What does it mean ?
Daanish - 返信
My sony handycam DCR-SR68 HDD not formating plz find
bharat kumar solanki - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 39
過去 30 日: 111
今までの合計 10,754
