Sony Cyber-shot DSC-W290 Flash Bulb Replacement
はじめに
手順 1 に進むMake sure you have all of the requisite tools on hand before beginning to replace the flash bulb.
Find the hatch labeled "open" on the left side of the bottom of the camera.
Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
Remove the four 2.5mm Phillips #0 screws.
Turn the camera so the back is facing you.
Remove the 2.5mm Philips #0 screw at the top of the camera.
Pull the top of the camera off and turn it so the bottom is facing you.
Desolder the three connections from the bulb to the small circuit board.
Remove the excess solder using your soldering iron and desoldering wick.
