Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement
5 - 10 分
簡単
はじめに
手順 1 に進むBy following 4 easy steps, you will be able to open the camera, locate the tripod receptacle, and replace it.
必要な工具と部品
Remove all seven black 4 mm Philips #00 screws holding the front panel into place. Two on each of the sides of the camera and three on the bottom.
Remove the one sliver 4mm Philips #00 screw that is holding the receptacle in place near the bottom of the camera.
この手順で使用する道具:Tweezers$4.99
Remove the tripod receptacle by simply lifting it out with your hands or with tweezers if necessary.
もう少しです!
終わりに
