メインコンテンツにスキップ
Sony Cyber-shot DSC-HX100V Viewfinder Replacement
DaQuawn
DaQuawn とその他 4 人の作成者
最終更新日: January 15, 2021
10分
簡単
アクションショット
If you have a faulty viewfinder and would like to know how to replace it yourself, this guide will show you how to do just that. By following these 6 simple steps, you will have your camera repaired within a few minutes and you will also save a couple of bucks.
必要な工具と部品
ツール
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Sony Cyber-shot DSC-HX100V Viewfinder Replacement, Viewfinder: 手順 1、 1の画像 1
    • Make sure camera is turned off.
    • Press the ON/Off button to turn off the camera.
    • WARNING: Data may be lost if the camera remains on.
  2. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 手順 2、 3の画像 1 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 手順 2、 3の画像 2 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 手順 2、 3の画像 3
    • Use the Phillips screwdriver size #00 to remove the 1.59mm #00 screws.
    • Remove 2 screws from the side of the camera.
    • Remove 4 screws on the bottom of the camera.
    • Remove 1 screw next to the eyepiece.
  3. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 手順 3、 1の画像 1
    • Flip the screen back to reveal 2 hidden screws.
    • Remove the two 1.59mm #00 screws on the left with the Phillips #00 screwdriver.
  4. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 手順 4、 1の画像 1
    • Pull the back panel of the camera upward.
    • Use a spudger to help pry open the back panel.
  5. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 手順 5、 1の画像 1
    • Open the back panel to view the inside of the camera.
    • If the orange ribbon cable disconnects from its designated port, do not panic. The cable is easy to reinsert.
  6. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 手順 6、 3の画像 1 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 手順 6、 3の画像 2 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 手順 6、 3の画像 3
    • Carefully pull out the the eyepiece.
    • Detach the orange ribbon cable that connects it to the green panel by carefully pulling outwards.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
DaQuawn
メンバー登録日: 03/05/15
254 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team 11-3, Blackburne Winter 2015 Sam Houston State, Team 11-3, Blackburne Winter 2015人のメンバー
SHSU-BLACKBURNE-W15S11G3
3 メンバー
8のガイドは作成済み
1件のガイドコメント
Thank you very much for the importent articles made for us. If I can please put , how to replace the flasher as well.
Satsara Gunaratne - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 995
