メインコンテンツにスキップ
Sony Cyber-shot DSC-HX1 Lens Assembly Replacement
Brianna Greenlaw
Brianna Greenlaw とその他 人の作成者
最終更新日: January 14, 2021
40 - 45 分
難しい
To take out and replace the lens assembly, you must first completely remove the central motherboard and all other internal components.
必要な工具と部品
ツール
  1. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 2、 1の画像 1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 3、 2の画像 1 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 3、 2の画像 2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
  4. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Motherboard: 手順 4、 2の画像 1 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Motherboard: 手順 4、 2の画像 2
    • Close the battery cover by pushing the cover inwards and sliding it to the left to allow more maneuverability when disassembling other parts of the camera.
  5. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 5、 1の画像 1
    • Unscrew the four #00 4.0 mm Phillips screws on the bottom of the camera.
  6. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 6、 1の画像 1
    • Remove the two #00 4.0 mm Phillips screws shown on the side of the camera.
  7. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 7、 1の画像 1
    • Unscrew the #00 4.0 mm Phillips screw on the top next to the view finder.
  8. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 8、 1の画像 1
    • Pull open the plastic port covers on the side of the camera.
    • Remove the revealed #00 4.0 mm Phillips screw.
  9. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 9、 3の画像 1 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 9、 3の画像 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 9、 3の画像 3
    • Lift the back LCD screen to reveal the back of the camera unit.
    • Unscrew the three #00 4.0 mm Phillips screws at the edge and center of the back camera unit.
  10. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 10、 3の画像 1 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 10、 3の画像 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 10、 3の画像 3
    • Using the plastic opening tool, pry apart the bottom of the camera at the line between the four removed screws.
    • Place the camera on its lens and use the plastic opening tool to pry at the crack in the case on all four sides of the camera.
    • Apply moderate force to the backside of the camera enclosure until the two pieces separate.
  11. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 11、 2の画像 1 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 11、 2の画像 2
    • Remove the #00 4.0 mm Phillips screw and the #00 6.0 mm Phillips screw holding the motherboard to the front enclosure.
    • Disconnect the eight ribbon cables from their ports on the motherboard.
  12. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 12、 2の画像 1 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 12、 2の画像 2
    • Detach the metal bracket from the enclosure by removing the two #00 4.0 mm Phillips screws.
  13. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 13、 2の画像 1 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 13、 2の画像 2
    • If you feel resistance from the board, double check all screws and cables have been removed to avoid damage.
    • Completely remove the motherboard by gently pulling the board away from the camera.
  14. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Lens Assembly: 手順 14、 1の画像 1
    • Unscrew the #00 6.0 mm Phillips screw on the left side of the lens.
  15. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 15、 2の画像 1 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: 手順 15、 2の画像 2
    • The lens assembly contains exposed leads to capacitors. Be very careful to avoid contact or discharge capacitors before handling as touching the capacitors could lead to electric shock.
    • Gently slide the lens assembly out of the front camera housing and remove completely.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Brianna Greenlaw
メンバー登録日: 04/06/15
1,217 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 17-3, Forte Spring 2015 Cal Poly, Team 17-3, Forte Spring 2015人のメンバー
CPSU-FORTE-S15S17G3
4 メンバー
10のガイドは作成済み
2 件のコメント
Hi!
Very good tutorial, thanks a lot.
I have a question : after reassembling the device, do you need to do some kind of adjustment or is it "simply plug-and-play"?
Best regards,
Marin
Marin Aymon - 返信
Muy bueno el tutorial felicitaciones, sin embargo faltaron tornillos por nombrar, saludos
Cesar Carrillo - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 24
過去 30 日: 72
今までの合計 5,759
