メインコンテンツにスキップ
Samsung Galaxy Tab Pro 10.1 Battery Replacement
Stephen Yeung
Stephen Yeung とその他 9 人の作成者
最終更新日: August 17, 2024
8 - 15 分
中レベル
多くの画像が必要
This guide will show you how to replace the battery on the Samsung Galaxy Tab Pro 10.1. First, the process will involve removing the rear panel of the device which will allow access to the interior where the battery is located. Then, the steps to remove the battery for replacement will be outlined.
必要な工具と部品
パーツ
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Samsung Galaxy Tab Pro 10.1 Battery Replacement, Rear Panel: 手順 1、 2の画像 1 Samsung Galaxy Tab Pro 10.1 Battery Replacement, Rear Panel: 手順 1、 2の画像 2
    • Be gentle, the front panel is connected to sensitive wiring that may snap if too much pressure is applied.
    • Insert a plastic opening tool into the crevice between the screen and the side of the tablet.
    • Go around the entire crevice with the plastic opening tool.
    • Set aside the separated front and rear panels of the device.
  2. Samsung Galaxy Tab Pro 10.1 Battery Replacement, Battery: 手順 2、 2の画像 1 Samsung Galaxy Tab Pro 10.1 Battery Replacement, Battery: 手順 2、 2の画像 2
    • Remove the six 4 mm Phillips #00 screws that hold the battery in place.
  3. Samsung Galaxy Tab Pro 10.1 Battery Replacement: 手順 3、 3の画像 1 Samsung Galaxy Tab Pro 10.1 Battery Replacement: 手順 3、 3の画像 2 Samsung Galaxy Tab Pro 10.1 Battery Replacement: 手順 3、 3の画像 3
    • Remove the tape that runs along the length of the battery.
    • Lift the retaining flaps of the ZIF connectors on each side of the battery connector.
    • Remove the two ribbon cables that lie across the width of the battery and are connected to the motherboard. Place your finger underneath the ribbon cable and gently lift the cable upwards and off.
  4. Samsung Galaxy Tab Pro 10.1 Battery Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab Pro 10.1 Battery Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Using tweezers, remove the top center 6 pin power connector that is attached to the edge of the motherboard from the center of the battery. To unplug it, pull it upwards away from the motherboard.
    • Detach the battery by gently lifting the battery out of the panel.
終わりに
21 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Stephen Yeung
メンバー登録日: 08/26/15
1,547 ポイント
6のガイドは作成済み
8ガイドコメント
My Samsung Galaxy Tab Pro sm-t520 screen pooped up from the base where the plugin for charging, only partly, and the screen is pretty much bowed up what can I do and the home button is very loose just happened by itself heard a pop like plastic sound and then looked and now Where home button is screen bowed up slightly how can that happen, I use the charger etc that came with my tablet and what would it cost to fix around figure possibly can a battery go bad even when I have not charged it in a long time, have not even been playing on it for several weeks. Please help ty
Cynthia Avey - 返信
Oh it was a loud snap sound.
Cynthia Avey - 返信
@cyndee Have you followed the guide above to open the tablet and looked at the battery? Can you see anything unusually? How does it look around the home button when you opened it?
Claes - 返信
Well can't open it cause have not the right tools.
Cynthia Avey - 返信
I would invest in a Opening Tools
like the one from ifixit so you can open the tablet. You need to see how it looks inside to know if you can repair and how.
Claes -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 19
過去 30 日: 87
今までの合計 45,096
