はじめに
Use this guide to remove or replace the screen on your Samsung Galaxy Note10+.
Due to the Note10+’s design, you will have to remove the back panel in order to disconnect the screen cable.
Before you begin this procedure, be sure to have a set of replacement adhesives for both the back panel and the screen.
必要な工具と部品
Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
Tilt the metal shielding up so you can grip it with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
この手順で使用する道具:Tweezers$4.99
Use a pair of tweezers to remove the loudspeaker.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to disconnect the S-Pen touch layer cable connector from the motherboard.
Prepare an iOpener and apply it to the left edge of the display for one minute.
Apply a suction cup to the heated edge of the display, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the display and the frame.
Prepare an iOpener and apply it to the bottom edge of the phone for one minute.
Prepare an iOpener and apply it to the top edge of the phone for one minute.
Prepare an iOpener and apply it to the right edge of the phone for one minute.
34 の人々がこのガイドを完成させました。
10件のガイドコメント
Thanks for the hard work that was put into this so are able to fix our own phones. Very much appreciated!
George Ray - 返信
How do you take the front glass screen off the OLED display/ screen? I couldn't find anything on this site. You would think they would because you can buy just glass screen that goes on the front of the OLED display.
Hi Austin,
Removing the front glass requires slicing through the LOCA (liquid optically clear adhesive), which is pretty tricky to complete and requires specialty tools. The screen glass part by itself is bought primarily by refurbishment/repair shop companies that have the necessary tools to complete that kind of repair.
Hello, does fingerprint sensor and face recognition works after replacing display+frame assembly? New part is original, not OEM.
