メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Note10+ Rear Camera Module Replacement
必要な工具と部品
  1. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the SIM card: 手順 1、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the SIM card: 手順 1、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the SIM card: 手順 1、 3の画像 3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the top edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Galaxy Note10+ Rear Camera Module Replacement, Heat the rear cover: 手順 2、 1の画像 1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Galaxy Note10+ Rear Camera Module Replacement, Insert an opening pick: 手順 3、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Insert an opening pick: 手順 3、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Galaxy Note10+ Rear Camera Module Replacement, Begin to slice the adhesive: 手順 4、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Begin to slice the adhesive: 手順 4、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Begin to slice the adhesive: 手順 4、 3の画像 3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Galaxy Note10+ Rear Camera Module Replacement, Slice around the perimeter of the phone: 手順 5、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Slice around the perimeter of the phone: 手順 5、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Slice around the perimeter of the phone: 手順 5、 3の画像 3
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Galaxy Note10+ Rear Camera Module Replacement, Lift off the rear cover: 手順 6、 2の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Lift off the rear cover: 手順 6、 2の画像 2
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Galaxy Note10+ Rear Camera Module Replacement, Lift up the metal cover: 手順 7、 1の画像 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
    FixBotに聞いてみる
    コメントを追加
  8. Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 8、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 8、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
    FixBotに聞いてみる
    コメントを追加
  9. Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the battery: 手順 9、 2の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the battery: 手順 9、 2の画像 2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
    FixBotに聞いてみる
    コメントを追加
  10. Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the wireless charging coil: 手順 10、 2の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the wireless charging coil: 手順 10、 2の画像 2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  11. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the wireless charging coil: 手順 11、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the wireless charging coil: 手順 11、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the wireless charging coil: 手順 11、 3の画像 3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
    FixBotに聞いてみる
    コメントを追加
  12. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the loudspeaker screws: 手順 12、 1の画像 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
    FixBotに聞いてみる
    コメントを追加
  13. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the loudspeaker: 手順 13、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the loudspeaker: 手順 13、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the loudspeaker: 手順 13、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to remove the loudspeaker.
    FixBotに聞いてみる
    コメントを追加
  14. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the interconnect cables: 手順 14、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the interconnect cables: 手順 14、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the interconnect cables: 手順 14、 3の画像 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
    • Disconnect the secondary interconnect cable from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  15. Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 15、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 15、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 15、 3の画像 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
    • Disconnect the secondary interconnect cable from the daughterboard.
    FixBotに聞いてみる
    コメントを追加
  16. Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 16、 2の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 16、 2の画像 2
    • Remove both interconnect cables.
    FixBotに聞いてみる
    コメントを追加
  17. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the top plastic cover: 手順 17、 1の画像 1
    • Use a Phillips screwdriver to remove the four 4 mm screws securing the top plastic cover.
    FixBotに聞いてみる
    コメントを追加
  18. Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 18、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 18、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 18、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to pivot the top plastic cover up and off of the phone.
    FixBotに聞いてみる
    コメントを追加
  19. Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect motherboard connectors: 手順 19、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect motherboard connectors: 手順 19、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect motherboard connectors: 手順 19、 3の画像 3
    • Use the pointed end of a spudger to disconnect the touch layer connector from the motherboard.
    • Disconnect the side button connector from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  20. Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 20、 2の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 20、 2の画像 2
    • Use the pointed end of a spudger to disconnect the S-Pen charging coil connector from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  21. Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 21、 2の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 21、 2の画像 2
    • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  22. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the motherboard: 手順 22、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the motherboard: 手順 22、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the motherboard: 手順 22、 3の画像 3
    • Use the pointed end of a spudger to pry up the motherboard enough to grip it with your fingers.
    • Remove the motherboard.
    FixBotに聞いてみる
    コメントを追加
  23. Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the rear camera module: 手順 23、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the rear camera module: 手順 23、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the rear camera module: 手順 23、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to remove the small piece of tape covering the middle camera connector.
    FixBotに聞いてみる
    コメントを追加
  24. Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 24、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 24、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 24、 3の画像 3
    • Use the pointed end of a spudger to disconnect the bottom camera connector.
    • Disconnect the middle camera connector.
    FixBotに聞いてみる
    コメントを追加
  25. Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 25、 2の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement: 手順 25、 2の画像 2
    • Use the pointed end of a spudger to disconnect the top camera connector.
    FixBotに聞いてみる
    コメントを追加
  26. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the rear camera module: 手順 26、 3の画像 1 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the rear camera module: 手順 26、 3の画像 2 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the rear camera module: 手順 26、 3の画像 3
    • Use a pair of tweezers or your fingers to remove the rear camera module.
    FixBotに聞いてみる
    コメントを追加
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Carsten Frauenheim
メンバー登録日: 03/10/20
167,580 ポイント
439のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
31,437のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 89
今までの合計 5,420
