メインコンテンツにスキップ
Samsung Galaxy A8(2018) Back Cover Replacement
Jean pierre bourhis
Jean pierre bourhis とその他 人の作成者
最終更新日: June 27, 2022
20 - 50 分
中レベル
文法の修正
コミュニティメンバーによる寄稿ガイド
This tutorial will show how to replace the back cover of your Galaxy A8.
Opening the phone will damage the waterproof seals. If you do not replace the adhesive gaskets, your phone will work normally, but will no longer be waterproof.
You will likely need replacement adhesive to reattach the back cover.
  1. Samsung Galaxy A8(2018) Back Cover Replacement, Back cover: 手順 1、 2の画像 1 Samsung Galaxy A8(2018) Back Cover Replacement, Back cover: 手順 1、 2の画像 2
    • Turn off your phone.
    • Prepare an iOpener or hair dryer to soften the adhesive on the back of the A8.
    • The adhesive is distributed over the outline of the back cover shown in red in the photo.
  2. Samsung Galaxy A8(2018) Back Cover Replacement: 手順 2、 1の画像 1
    • Use a suction cup to lift the back cover and insert an opening pick into the slot created.
    • Start in the middle and cut the adhesive while maintaining tension on the suction cup.
    • If you find it increasingly difficult to move the pick, reheat the iOpener or use a hair dryer.
  3. Samsung Galaxy A8(2018) Back Cover Replacement: 手順 3、 2の画像 1 Samsung Galaxy A8(2018) Back Cover Replacement: 手順 3、 2の画像 2
    • Move your pick carefully from corner to corner. Leave a pick at each corner once it has been freed to prevent the cover from re-adhering. Repeat for all 4 corners.
    • Do not force the cover open. Re-soften the adhesive with an iOpener or hair dryer if the back cover does not come off or begins to warp.
    • On the photo opposite three corners have been released, with one corner remaining to be able to completely remove the glass.
    • Be careful not to damage the fingerprint reader connector when opening the back cover. Disconnect it following the instructions in the next step.
  4. Samsung Galaxy A8(2018) Back Cover Replacement: 手順 4、 1の画像 1
    • Unplug the fingerprint reader with tweezers.
  5. Samsung Galaxy A8(2018) Back Cover Replacement: 手順 5、 1の画像 1
    • Remove the back cover.
    • Prepare for reassembly by removing the remaining adhesive from the phone with a spudger. Clean the adhesive surfaces with isopropyl alcohol and a lint-free cloth.
終わりに
To reassemble your device, follow the instructions in reverse order.
7 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
100%
Jerry Wheelerさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Jean pierre bourhis
メンバー登録日: 03/06/18
361 ポイント
1ガイドが承認済み
チーム
Leroy Merlin Leroy Merlin人のメンバー
Community
38 メンバー
241のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 93
今までの合計 3,748
