メインコンテンツにスキップ
Samsung Galaxy A15 Front Camera Replacement
必要な工具と部品
  1. Samsung Galaxy A15 Front Camera Replacement, Prepare your phone for disassembly: 手順 1、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement, Prepare your phone for disassembly: 手順 1、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement, Prepare your phone for disassembly: 手順 1、 3の画像 3
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Unplug all cables and completely power off your phone.
    • Press and hold the power and volume down buttons at the same time to bring up the shutdown menu.
  2. Samsung Galaxy A15 Front Camera Replacement, Heat the right edge: 手順 2、 1の画像 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back are susceptible to heat damage. The phone should be just too hot to touch comfortably.
  3. Samsung Galaxy A15 Front Camera Replacement: 手順 3、 1の画像 1
    • While you're waiting for the adhesive to soften, here is some useful information:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • There is an additional layer of adhesive towards the bottom of the phone. Apart from this area, you should not be deeper than 4 mm from the edge.
  4. Samsung Galaxy A15 Front Camera Replacement, Insert an opening pick: 手順 4、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement, Insert an opening pick: 手順 4、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement, Insert an opening pick: 手順 4、 3の画像 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
  5. Samsung Galaxy A15 Front Camera Replacement, Slice the adhesive: 手順 5、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement, Slice the adhesive: 手順 5、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement, Slice the adhesive: 手順 5、 3の画像 3
    • Slide your opening pick along the right edge between the back cover and the frame to slice through the adhesive.
    • Leave your opening pick in the bottom right corner to keep the adhesive from resealing.
  6. Samsung Galaxy A15 Front Camera Replacement: 手順 6、 1の画像 1
    • Reheat your iOpener and apply it to the bottom of the back cover for two minutes.
  7. Samsung Galaxy A15 Front Camera Replacement: 手順 7、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement: 手順 7、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement: 手順 7、 3の画像 3
    • Insert another opening pick in the bottom right corner and slide it along the bottom edge to slice through the adhesive.
    • Leave your opening pick in the bottom left edge to prevent the adhesive from resealing.
  8. Samsung Galaxy A15 Front Camera Replacement: 手順 8、 1の画像 1
    • Reheat your iOpener and apply it to the left side of the back cover for two minutes.
  9. Samsung Galaxy A15 Front Camera Replacement: 手順 9、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement: 手順 9、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement: 手順 9、 3の画像 3
    • Insert another opening pick in the bottom left corner and slide it along the left edge to slice through the adhesive.
    • Leave your opening pick in the top left corner to prevent the adhesive from resealing.
    • Only insert your pick up to 4 mm deep to avoid damaging the rear cameras or flash.
  10. Samsung Galaxy A15 Front Camera Replacement: 手順 10、 1の画像 1
    • Reheat your iOpener and apply it to the top of the back cover for two minutes.
  11. Samsung Galaxy A15 Front Camera Replacement: 手順 11、 2の画像 1 Samsung Galaxy A15 Front Camera Replacement: 手順 11、 2の画像 2
    • Insert another opening pick in the top left corner at the same depth and slide it along the top edge to slice through the adhesive.
    • Leave your opening pick in the top right corner to prevent the adhesive from resealing.
  12. Samsung Galaxy A15 Front Camera Replacement, Unfasten the camera clips: 手順 12、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement, Unfasten the camera clips: 手順 12、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement, Unfasten the camera clips: 手順 12、 3の画像 3
    • Insert your opening pick along the top edge of the phone and twist it gently to unfasten the camera clips.
    • Slide your opening pick around the edge of the camera modules to unfasten the remaining camera clips.
    • Only insert your pick up to 4 mm to avoid damaging the rear cameras or flash.
  13. Samsung Galaxy A15 Front Camera Replacement, Slice remaining adhesive: 手順 13、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement, Slice remaining adhesive: 手順 13、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement, Slice remaining adhesive: 手順 13、 3の画像 3
    • Once the adhesive around the edges is loose, insert your opening pick deeper into the bottom edge from the bottom left corner.
    • Slide your pick deeper into the phone across the bottom edge, slicing the remaining adhesive.
  14. Samsung Galaxy A15 Front Camera Replacement, Remove the back cover: 手順 14、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement, Remove the back cover: 手順 14、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement, Remove the back cover: 手順 14、 3の画像 3
    • Lift and remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  15. Samsung Galaxy A15 Front Camera Replacement, Remove the SIM tray: 手順 15、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement, Remove the SIM tray: 手順 15、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement, Remove the SIM tray: 手順 15、 3の画像 3
    この手順で使用する道具:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located towards the top of the phone on the left edge.
    • Press in firmly to eject the tray and remove it.
  16. Samsung Galaxy A15 Front Camera Replacement, Remove the frame screws: 手順 16、 1の画像 1
    • Remove the fifteen 4 mm-long screws connecting the frame to the chassis.
  17. Samsung Galaxy A15 Front Camera Replacement, Disconnect the fingerprint button: 手順 17、 2の画像 1 Samsung Galaxy A15 Front Camera Replacement, Disconnect the fingerprint button: 手順 17、 2の画像 2
    • Use the flat end of a spudger to pry up and disconnect the fingerprint button press connector from the motherboard.
  18. Samsung Galaxy A15 Front Camera Replacement, Unfasten the frame clips: 手順 18、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement, Unfasten the frame clips: 手順 18、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement, Unfasten the frame clips: 手順 18、 3の画像 3
    • Insert your opening pick above the SIM card tray cutout to form a gap between the frame and the phone.
    • Slide your opening pick down the left edge of the device to unfasten the frame clips.
  19. Samsung Galaxy A15 Front Camera Replacement: 手順 19、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement: 手順 19、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement: 手順 19、 3の画像 3
    • Continue sliding your opening pick around the perimeter of the phone until all of the clips are unfastened.
    • If your opening pick comes out of the phone, re-insert it at the last unfastened corner.
  20. Samsung Galaxy A15 Front Camera Replacement, Remove the frame: 手順 20、 2の画像 1 Samsung Galaxy A15 Front Camera Replacement, Remove the frame: 手順 20、 2の画像 2
    • Pull the frame straight off of the phone.
  21. Samsung Galaxy A15 Front Camera Replacement, Disconnect the battery: 手順 21、 2の画像 1 Samsung Galaxy A15 Front Camera Replacement, Disconnect the battery: 手順 21、 2の画像 2
    • Use the flat end of a spudger to lift up and disconnect the battery press connector.
  22. Samsung Galaxy A15 Front Camera Replacement, Remove the front camera: 手順 22、 3の画像 1 Samsung Galaxy A15 Front Camera Replacement, Remove the front camera: 手順 22、 3の画像 2 Samsung Galaxy A15 Front Camera Replacement, Remove the front camera: 手順 22、 3の画像 3
    • Use the flat end of a spudger to lift up and disconnect the front camera press connector.
    • Remove the front camera.
終わりに
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
ある他の人がこのガイドを完成しました。
Nick Schultz
メンバー登録日: 03/24/24
15,802 ポイント
87のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,450のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 53
今までの合計 385
