メインコンテンツにスキップ
Samsung Galaxy A12 Battery Replacement
Osvaldo G
Osvaldo G とその他 人の作成者
最終更新日: December 20, 2024
10分
簡単
コミュニティメンバーによる寄稿ガイド
Here's a quick guide to replace the battery
必要な工具と部品
パーツ
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Samsung Galaxy A12 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Turn off the smartphone
    • Place your smartphone on a safe surface
  2. Samsung Galaxy A12 Battery Replacement: 手順 2、 2の画像 1 Samsung Galaxy A12 Battery Replacement: 手順 2、 2の画像 2
    • Use the iFixit Opening Picks to pry open the plastic back of the smartphone.
    • **Be careful of pulling too hard the fingerprint sensor cable is connected to the plastic back** (see second picture)
  3. Samsung Galaxy A12 Battery Replacement: 手順 3、 1の画像 1
    • Remove the covers with the screwdriver.
    • **Be careful with touching anything with the screwdriver in the motherboard**
  4. Samsung Galaxy A12 Battery Replacement: 手順 4、 1の画像 1
    • Now that we have the covers removed the phone back should look like this
    • Before continuing we need to remove the fingerprint sensor.
    • While you can use the Spudger. I used the iFixit Opening Tool for this video example.
    • Use the Spudger to detach the main board cable gently
    • Move to the battery cable
    • **Both cables are crucial for the smartphone to be operational treat gently **
終わりに
12 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Osvaldo G
メンバー登録日: 11/17/20
554 ポイント
1ガイドが承認済み
2 件のコメント
SAMSUNG A 12
1) opening the case is a challenge.
Remove the sim card with pin after you power off the phone!
After some prying with a pocket knife ( found bottom left corner , viewed from the phone front ...->was able to partial separate the case. With a helper, they inserted the stick pry tool in the crack and the with continuous inward pressure slide tool up along the crack to the top of phone. Back to pocket knife 2x- 3x more times to release additional aspects of case.
2)The videos are very useful.
3) The battery on my phone was held in with 2way tape. I used two coins,suggest dimes to pry battery bottom* (*opposite end of small battery connector) Then using picks on the sides as it very gradully opens up. I took me at close to a min. to gradually pry it out.
4)
I used a couple small peice of 2way tape on the new battery prior to installing it.
I owned a consumer electronics store and did a variety of electronics repairs.
Thought these details would be helpful.
Dennis - 返信
Stick pry tool should have said pick pry tool.
Dennis
Dennis - 返信
コメントを追加
統計データ:
過去 24時間: 24
過去 7 日: 127
過去 30 日: 440
今までの合計 6,822
